Thread Tools Display Modes
Old 12-06-2005, 10:43 AM   #1
Steve Slinkard
New Member
Steve Slinkard is on a distinguished road
Default Router Plate Template
I'm building a router table and need a method to make the template for routing out the inset for the router plate. I've tried using my circular saw, jig saw, table saw, all unsuccessfully. There must be a method that uses the router to make a very precise template. Can anyone tell me where I can go to learn how this can be done?
Thanks in advance.
Steve
Steve Slinkard is offline   Top - Reply with Quote
Old 12-06-2005, 11:05 AM   #2
jerrymayfield
Forum Geek
I can tell you one of the ways I have done it. Attach your plate to a piece of 1/4" BB plywood,next use a 1/4"spiral bit and a 1/2" collar guide,template guide,or whatever its called and cut the pattern in the plywood. You now have a pattern that is a copy of your plate,but 1/8" larger. Attach this pattern to your table(double stick tape,nails, whatever works) using the same bit and guide cut the recess. You will have to accomodate the plate by cutting the approximent depth of your plate or using something similar to the plate levelers used by Woodhaven.
Regards
Jerry
Old 12-06-2005, 01:50 PM   #3
-Sam-
Forum King
-Sam-'s Avatar
-Sam- is on a distinguished road
Steve,
Here's one of my favorite operations for making that recess. Just click here!
Sam
Retired Forum Moderator
Refer a friend to RouterForums.com!
-Sam- is offline   Top - Reply with Quote
Old 12-07-2005, 09:07 AM   #4
jerrymayfield
Forum Geek
Very original, I'm sure a lot of thought went into the answer.
Jerry
Old 12-07-2005, 12:36 PM   #5
Steve Slinkard
New Member
Thanks for your idea. I'll give it a try and let you know how it turned out
Steve
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 07:00 PM
Where can I find this Slick method for cutting router plate opening into table Peter Sanders Table-mounted Routing 23 01-23-2008 09:42 AM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 02:08 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
