| This is a discussion on Question about acrylic thickness within the Jigs and Fixtures forums, part of the Routers category; I have a chance to buy a sheet of either acrylic or polycarbonate (not sure ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I have a chance to buy a sheet of either acrylic or polycarbonate (not sure which it is) which measures 3.5ft x3.5ft x 3/8inch for $15 which I think is quite cheap. Is 3/8inch to thick to use for a router base? I see that my factory base is only 0.219inch. | ||
| | #2 (permalink) | ||
I would buy it to make a plate. I would not use thinner than 3/8" acrylic for a plate. 1/4" if the plate was aluminum.
__________________ James Whittier, CA. http://www.deltaportercable.com/jigs...lJigManual.pdf http://www.deltaportercable.com/jigs...ntalManual.pdf | ||
| | #3 (permalink) | ||
| Forum Contributor ![]() |
3/8" is fine. That's a great price.
__________________ . Never, under any circumstances, combine a sleeping pill and a laxative on the same night. Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ | ||
| | #4 (permalink) | |||
__________________ John Schaben ![]() "I haven't failed, I have simply discovered several hundred ways that don't work" | |||
| | #5 (permalink) | ||
Hi Not the best for router base plates but for the price you can use it for many other things. It's best to use 1/4" thick, the screws that hold on the bases are so long and if you want to use the brass guides it's bit to thick, 1/16" is a big deal with the brass ring nut.. ========
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | ||
| | #6 (permalink) | |||
__________________ James Whittier, CA. http://www.deltaportercable.com/jigs...lJigManual.pdf http://www.deltaportercable.com/jigs...ntalManual.pdf | |||
| | #7 (permalink) | ||
Well, the guy was coming through town so I had him deliver the acrylic. That saved me $6 in gas ![]() It measures 39"x41". He was wrong about the thickness, its 1/4" not 3/8". Actually it varies from .249-.273"...hmmm. Its quite scatched and smudged but it was also $15. It should easily polish up with some 2000 grit and some polishing compound. And if I'm not mistaken, according to web sites I looked at I have nearly $100 worth of acrylic. Is that right or not? Is there a way to tell if it is acrylic or polycarbonate or what? | ||
| | #8 (permalink) | ||
I spent $18.00 on a peice that was 12 x 12 x 1/8"
| | #9 (permalink) | ||
Hi Surfer - somebody comes around me with a chunk that size for 15 bucks he wouldn't see which pocket the money came out of ![]() Seriously, here's a link to where I usually order stuff: eStreetPlastics - plexiglass sheet supplier Lexan (polycarbonate) is significantly more expensive, a bit softer and much stronger. According to the website, 1/4" nominal will run from .190 to .250 so sounds like you got a pretty decent piece. If it is pretty well scratched up I would guess you got Lexan. Read someplace if you take a small piece, say an inch square and smack it with a hammer, plexiglass will crack/break, polycarbonate will just bounce around. ![]() Nice score on the plastic
| | #10 (permalink) | ||
| Moderation Team ![]() |
Sounds like it would make great template or jig material ![]()
__________________ EGO postulo , EGO venalicium , EGO incidere. I measured, I marked, I cut. Latin instructions for firewood. | ||
| Routing Acrylic .... | lemonyx | General Routing | 23 | 12-04-2009 02:00 AM |
| Polycrilic Plate Thickness | cbsjoez1935 | Starting Off | 5 | 09-28-2009 07:56 PM |
| [FAQ] How to Post a Question | Mark | Forum Help & FAQ | 0 | 01-11-2009 10:26 PM |
| Question on Router Table Top and Fence | Sierramtns | Table-mounted Routing | 3 | 09-20-2008 04:47 PM |
| DC Question | angus | Lobby | 3 | 03-31-2008 08:29 PM |
