| This is a discussion on DIY concealed hinge jig within the Jigs and Fixtures forums, part of the Routers category; Hi all, I'm trying to figure out the easiest way to route some recesses for ... |
| | #1 (permalink) | ||
| Registered User ![]() |
Hi all, I'm trying to figure out the easiest way to route some recesses for hinges in a cabin door. I don't think I will be doing this very regularly, so I would prefer something fast & cheap & diy - I'm sure there's a lot of great proper solutions for this, but right now I just want to get the job done and there's only 4 doors to make ![]() I was thinking about something like the Rockler's concealed hinge jig. It seems fairly simple to make. But. For my hinges, I need a 35mm recess. My plunge router has a 16mm copy collar and I have bits like 6mm and 12mm (Sorry for the metric measures, but it's easier for me to keep the information correct). So I made an excel sheet and figured that for the 6mm bit to work I'd need a 45mm hole in the template. For the 12mm, the hole would have to be 39mm. Unfortunately, I don't have a matching hole saw, I have 44m, but no 45mm. So this idea doesn't seem to be that simple after all. Are there any other methods that would work for this? I was kind of hoping to get this done without buying any new tools ![]() Thanks! | ||
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community! |
| | #2 (permalink) | ||
| Forum Contributor ![]() |
Hi You can make a jig to do it or copy the Rockler one but if you have a forstner bit set you have what you need almost all sets come with a 1 3/8" bit that's the 35mm size you need..all you need is the drill press mark the door drill the pocket hole put the hinge in place drill two small holes for the screws to hold the hinge in place and you done with that one.. I will say I made 2 copies of the Rockler jig and they work very well but it takes time to make them and if you are just doing 4 doors,well you don't need to spend the time if it's one time thing for you.. ![]() =======
__________________ "It's fine to disagree with other members as long as you respect their opinions" MANY,MANY help files on John's web site http://legacy.woodshopdemos.com/menu2.htm Sommerfeld Tools ,Videos http://www.youtube.com/channel/UCT-n...RWaEpMA/videos | ||
| | #4 (permalink) | ||
Hi The 35mm ( 1 3/8" ) hole is critical like most hinges it's the pocket hole that does the work not the screws..you can get the set below or from just about any woodworking supply outlet will have them on hand, most are from 1/4" to 2 1/8" for 22.oo bucks the norm ...don't just buy a bit for the concealed hinges, you will pay thought the nose for it, just about 18.oo+ bucks the norm.. ![]() 10 Piece Titanium Nitride Coated Forstner Bit Set with Hex Shanks You can find sets of them on eBay all over the place at a good price but the freight will nail the good price,,MLCS at 35.oo bucks with free shipping and about 3 to 4 days. MLCS Forstner Bit Sets ========
| | #5 (permalink) | ||
Thanks, I have no prior hinge-experience, so all advice is very welcome. I'll see tomorrow what the bigger bits cost here. Unfortunately this sort of things are likely to be more expensive here (Finland) than in the US. Also any free shipping campaigns usually only apply in US/Canada, for understandable reasons. But, I will see tomorrow when I'll get to the hardware store. | ||
| | #6 (permalink) | |||
HI I can see your point being from the land of the blue cross, post back on what you had to pay for one ,I sure would like to know.. ![]() ======= Quote:
__________________ "It's fine to disagree with other members as long as you respect their opinions" MANY,MANY help files on John's web site http://legacy.woodshopdemos.com/menu2.htm Sommerfeld Tools ,Videos http://www.youtube.com/channel/UCT-n...RWaEpMA/videos | |||
| | #7 (permalink) | |||
Quote: | |||
Sponsored Advertisements. Register to disable this advertisement.
| | #8 (permalink) | ||
Oho ! A Finn and an Estonian in the same week ! Things are getting interesting. Incidentally, I needed to bore a 1" hole this week to make the hole for a 1" bushing in Bob's jig for following curved lines. My engineering stuff is still in store and my forstner bits are all metric. OK, I thought, 25mm is almost 25.4mm and these Chinese things are probably not all that accurate. It will probably do it. Did it, hell ! The damned thing was bang on 25mm ! You can't even trust this cheap Chinese stuff to be inaccurate! I'm probably going to have to import a 1" Forstner bit. I'll use it for something similar again. I did wonder if my Trend stuff would work instead of the brass PC bushings, as they are all metric and they fit another of my routers but, sod's law, the sizes are in increments of 2mm and there is no 25mm ! Thinking on, I suppose I could go to 30mm and I've a 30mm forstner bit. Duh! I should have thought of that before! Cheers Peter | ||
| | #9 (permalink) | |||
Yeah, the world gets smaller every day The fact that there are two different systems for measuring things causes frustration sometimes. I have experienced that with woodworking on free time and with 3d modeling at work. Now I finally realized what I should be looking at. So we are talking about a forstner bit for a regular drill, right? I was concentrated on routers and that's why I was thinking that such a bit might not even be available here Regular forstner bits are well available and not too expensive (starting from around $10), I will grab one today and head back to summer cabin where my project waits! Thanks again for the advice! | |||
| | #10 (permalink) | |||
Where are you? If you're in Europe, you should have the Forstner bit available specifically for the Blum hinges. At least here, (Canada) they sell the bits. There are 35mm and 40mm available. You know it's funny, we sell 2x4s and 1/2" drywall but hinges are metric. Go figure!
__________________ Allthunbs Canadians is your CBC worth your support? http://reimaginecbc.ca/connected | |||
| Akeda BC24 Dovetail Jig arrived! | Michael H | Jigs and Fixtures | 13 | 04-11-2012 09:50 PM |
| Shelf pin hole jig - reviews and router solution | Greg_R | Jigs and Fixtures | 11 | 11-14-2011 11:40 PM |
| New DIY Mortising Jig | WoodBrewer | Jigs and Fixtures | 11 | 03-23-2009 09:09 AM |
| Hinge mortising question | Dalec | Jigs and Fixtures | 8 | 03-02-2009 06:17 AM |
| Concealed Hinge Jig | bobj3 | Jigs and Fixtures | 11 | 02-24-2008 02:43 PM |
