Thread Tools Display Modes
Old 09-11-2004, 12:10 AM   #1
NewMontanaWorkshop
Forum Geek
NewMontanaWorkshop's Avatar
NewMontanaWorkshop will become famous soon enough
Default Homemade adjustable router fence.
Anyone have a homemade router fence that has an easy to adjust depth-of-cut feature? Not in a position to 'buy' a router fence, but I do have a sheet of 1/2" Baltic Birch just waiting to be used up in jigs/fences, etc.
I'm starting my woodworking learning curve on picture frames, and the constant 'bump and hope' method of my current rip fence mounted router fence is really not a good/accurate way to go as far as I can tell.
TIA.
NewMontanaWorkshop is offline   Top - Reply with Quote
Old 09-11-2004, 12:40 AM   #2
gmack5
gmack5 is on a distinguished road
I assume that you are talking about distance from the Fence to the router Bit.
This being the case, you could attach a 3/8-16 piece of all-thread to the back of the Router Fence (in the center), pass it thru a nut fixed to a bracket attached to the table.
This would give you 1/16th inch advance for each full turn of the knob that you will need to attach to the piece of All-thread, behind the bracket.
The attachment to the Router Fence would need to be capable of rotating, but with little or no slop.
gmack5 is offline   Top - Reply with Quote
Old 09-12-2004, 09:52 PM   #3
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
The system I use is like the one Bob & Rick use. It isn't fancy, but it is simple, accurate, and inexpensive to make. Two "C" clamps and a stick (wood or UHMW) works great.
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
Old 09-13-2004, 04:31 PM   #4
NewMontanaWorkshop
Forum Geek
Hmmm, haven't seen the one Bob & Rick use. Will have to look around for that one.
Thanks.
Old 09-13-2004, 11:34 PM   #5
Pop_pop1
Forum Fanatic
You might be able to watch them on "The Router Workshop" on your local PBS TV channel. They also have several books out. Good Stuff.
PopPop
Old 09-28-2004, 11:28 PM   #6
billyboy
billyboy is on a distinguished road
Default think this fits the bill...
TIA.
I built a fence using Baltic birch plywood. It consists of a fence "face" being dadoed to a base, and a base below it which "slides" on the upper portion, riding in two UHMW strips. A threaded rod with a knob on it connects the upper base to the lower, and a locking knob keeps the two from moving. To adjust, simply undo the locking knob, and turn the adjuster until the desired movement is achieved. You could even go to extremes, and build in a vernier gauge to get ultra accurate adjustments.
billyboy is offline   Top - Reply with Quote
Old 09-29-2004, 12:04 AM   #7
NewMontanaWorkshop
Forum Geek
Wouln't happen to have a picture or two would ya?
Old 09-29-2004, 08:45 AM   #8
kp91
Forum King
kp91's Avatar
First Name: Doug
I also keep it simple. For small measurements, I use the brass set up bars. For bigger distances, I set it up close as I can with a tape measure or machinist scale then test it on some scrap.
Once or twice I have cut a gage block on the table saw and used that to set the fence the right distance away for some dados I was cutting in the sides of a bookcase.
1 John 1:9
Old 09-30-2004, 04:34 AM   #9
Spacemanspiff
Sr. Member
Spacemanspiff is on a distinguished road
Here's mine from the back. I just used ratchet handles onto bolts that slide in grooves or tracks;
http://www.woodworkersweb.com/module...ter_behind.jpg
As you can see it also has adjustable faces. To move it I use a calibrated bump!! Just loosen off one side, move it a smidge and tighten it up. Easy as falling off a bike.
Aaron
The speed of light travels faster than the speed of sound, that's why people appear intelligent until they open their mouth ...
Spacemanspiff is offline   Top - Reply with Quote
Old 09-30-2004, 11:14 AM   #10
NewMontanaWorkshop
Forum Geek
Thanks for that picture Aaron, that gives me a few ideas to try. I just finished making my plates from some 'recovered from the dumpster' 3/4" plexiglass. Hope to get started on a router table this weekend.
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
Homemade split router fence seawolf21 Table-mounted Routing 7 01-27-2007 06:14 PM
Homemade router fence g-man Jigs and Fixtures 11 06-05-2006 01:33 PM
Face Lift for the Router Fence bobj3 Jigs and Fixtures 7 06-05-2006 09:57 AM
