| | #1 |
| Registered User Supreme Forum King | On one of the very few shows PBS has shown here in Arkansas, Bob and Rick used a spline jig and a slot cutter when they made the hexagon stool. Is there any way to get plans for this jig? Thanks, Boxer |
| | #2 |
| Registered User Jr. Member | I found a spline jig design in this book, which I checked out of my local library: The woodworkers guide to making and using jigs, fixtures and setups : how to get the most from every tool in your shop / David Schiff and Kenneth S. Burton, Jr. ; illustrations by Frank W. Rohrbach ; photography by Mitch Mandell. http://www.amazon.com/gp/product/087...Fencoding=UTF8 |
| | #3 |
| Registered User Supreme Forum King | Thanks for the reply. I do want to clarify that this is a spline jig they used to connect the legs together, and not a jig for mitered corners. I will look into the book, though. Kevin |
| | #4 |
| The Router Guys Forum King | I will get you some info on the jig Kevin...might be a couple of days though.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #5 |
| Registered User Supreme Forum King | I would really appreciate that. No hurry though. I can't thank you enough. Kevin |
| | #6 |
| Registered User Jr. Member | Kevin, your guess was right, the spline jig in the book is for mitered corners. |
| | #7 |
| Registered User Forum Geek | check this site out it has lot's of good information on about every type of joint scroll down the page and the spline joint is shown del schisler http://www.sawdustmaking.com/About%2...out_joints.htm Spline Joint This is a thin strip glued into grooves cut into the pieces being joined, these are used to fasten panels together and to fasten the mitered corners of picture frames. They are made with a table saw and dado blade or with a router and straight bit. Picture Frame Spline Jig Splines add strength to a miter joint, a simple jig can be made for use on a table saw or router table. The glued corner is clamped into the jig, the jig is run along the fence on your table saw or router table, the short dowel is used as a handle to keep the jig tight to the fence. Insert the spline, trim and sand even with frame when glue has set.
__________________ del schisler |
| | #8 |
| Forum Contributer Supreme Forum King | boxer Not to step on Ricks reply but I think this is the one you are talking about. Hope it helps you make one ,it's a quick and easy one to make. Bj ![]() |
| | #9 |
| Registered User Supreme Forum King | Thanks, Bob. That looks like it would work. What is the 1/4" x 2" slot in the sub-base for? |
| | #10 |
| Forum Contributer Supreme Forum King | Boxer The slot is made so you can replace the sub base with other types, like a 45deg.,15deg.,etc. just remove the wings nuts and the 1/4-20 x 2" carr. bolts and put the new one in place. Note**I grind the head down on the carr.bolt to 3/8" dia. and 3/16" high and run two slots one for the head and one for the screw, this way I full control of the sub.base. This can be done quick and easy with a drill and a grinder. Note **when you cut the 22 1/2 deg. put the cut off back on (glue it in place) then cut to the right size this will help support the part when you run the slot. Bj ![]() |
| Anyone use/have the Kehoe Dovetail Spline Jig? | thewoodennewfie | Jigs and Fixtures | 11 | 04-22-2008 08:10 AM |
| Spline miters | Blind Bruce | Table-mounted Routing | 5 | 01-10-2007 04:07 PM |
| Spline vs. Tongue & groove | wanart | General Routing | 1 | 02-28-2006 06:22 AM |
| Slot Cutter or Spline cutter | kimbert | General Routing | 3 | 10-20-2005 06:26 PM |
| dovetail spline joints | reible | Jigs and Fixtures | 7 | 10-02-2004 01:50 PM |
