| | #1 |
| Forum Contributer Supreme Forum King | This jig is replacement for the old one I had. Bearing ▼ from Oak-Park also http://us.oak-park.com/catalogue.htm...roduct=MBK0990 OR Mortise Centering Router Base,here's just one more way for 20.00 bucks http://www.rockler.com/product.cfm?p...7&filter=34553 http://www.rockler.com/gallery.cfm?O...Select=Details or pickup 2ea. 1/4-20 x 3" brass bolts and cut off the heads and some of the threads and drill and tap your base plate to take on the 2 brass studs... JUST a Note, Jerry ask how do you put the slot in the ends,?? I just added a picture or two showing how to do that... ===== Below,,just one more way to get the job done Mortise Centering Router Base http://www.rockler.com/product.cfm?p...ilter=mortises http://www.rockler.com/gallery.cfm?O...Select=Details ========= ====== Bj ![]() Last edited by bobj3; 04-28-2008 at 12:08 PM. |
| | #2 |
| Forum Contributer Supreme Forum King | I should note that the base is 5 1/4" wide X 24" long. (Poplar) The sides are glued and screwed into place with 4ea. 8 x 1 3/4" drywall screws. Bj ![]() |
| | #3 |
| Forum Contributer Supreme Forum King | New Part number for the Grizzly Bearing ▼ G3845 http://www.grizzly.com Oak-Park bearing set http://us.oak-park.com/catalogue.htm...roduct=MBK0990 Bj ![]() Last edited by bobj3; 03-09-2008 at 07:18 PM. |
| | #4 |
| Registered User Forum Geek | I may be missing something,but what I see is equipment for making mortises,or are you making mortises in both pieces and using loose tenons ?. Regards Jerry |
| | #5 |
| Forum Contributer Supreme Forum King | Hi Jerry "mortises in both pieces" = Yes Bj ![]() Last edited by bobj3; 12-27-2006 at 05:07 PM. |
| | #6 |
| Forum Contributer Supreme Forum King | I should post the other snapshots Bj ![]() Last edited by bobj3; 12-27-2006 at 05:08 PM. |
| | #7 |
| Forum Contributer Supreme Forum King | Just some add on snapshots Bj ![]() Last edited by bobj3; 12-27-2006 at 05:09 PM. |
| | #8 |
| Registered User New Member | If the Mortise is the hole that the Tenon fits into, I make them using a fence and a laser sight from a pistol which I hung from a rafter. I shine the light beam directly on the tip of the bit and mark the piece on the top. The laser light shines on the top of the piece and shows me where to start and where to stop. By hiting the marks I have drawn I follow the light to the next mark knowing that the bit is directly below the light and is doing its job of making an exact cut. I use the same method for making initials on the head board of doll beds. I use a computer to make the initials, copy them into the Paint program and ask that program to reverse them. I print that and tape it to the top of the piece of wood. The laser follows those letters and makes a correct copy on the reverse side. |
| | #9 |
| Forum Contributer Supreme Forum King | JimH Bj ![]() Last edited by bobj3; 12-27-2006 at 05:09 PM. |
| | #10 |
| Forum Contributer Supreme Forum King | Just a add on NOTE***How to use the jig. Last edited by bobj3; 12-27-2006 at 05:10 PM. |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
| Mortise & Tenon System Router questions | kenadian | Table-mounted Routing | 2 | 11-17-2005 04:22 PM |
