Tongue and Groove Jig - Router Forums
post #1 of 1 (permalink) Old 04-05-2011, 03:17 PM Thread Starter
First Name: Allen
Default Tongue and Groove Jig
I've 3/4" x 4' wood planks to join with varying widths. Kind of decided on tongue and groove for the joint. Wondering if anyone has suggestions on a jig to get consistent tongues and grooves? When finished a plank will be 10.5" width. Router is mounted under the table and I am using a fence.
The jig I have in mind will keep the wood being routed flat and not allow it to rise while being feed. Also, keeps the bit away from fingers. Jig / guide will be mounted to the fence 3/4" from the top of the table. The wood feeds flush with the top knifve for the tongue bit.
There's about 80' of planks to run. Some will be cut on both sides.
Does this seem correct? Have I missed something?
anyducks is offline
Human Verification
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
homemade tongue and groove panels overthehill Introductions 5 01-22-2009 11:56 PM
New to the forum - Advise PLEASE about Tongue and Groove Flooring Darby Introductions 7 03-25-2007 04:07 PM
Spline vs. Tongue & groove wanart General Routing 1 02-28-2006 06:22 AM
Tongue and groove bits archer_456 General Routing 4 02-18-2005 05:51 AM
