Rate This Thread - Cutting dado with hand router.
Thread Tools Display Modes
Old 06-12-2006, 04:36 PM   #1
simplenik
Forum Geek
simplenik is on a distinguished road
Default Cutting dado with hand router
Good day
I know that there are a few methods to cut dado.
I would like to share with you my way.
With this method, I always know where the “bit will hit” or cut.
“See NOTE in text”
When you see on the picture “See NOTE in text”, I did not have space on the picture to type:
“You can make the same knife mark on the other side of the board and move the plate with the slot to the other side and check that the knife mark is at the same distance (like the first one) from the board edge. If it’s not, shim the T guide.
Please let me know if the above note is not clear, I’ll try to make a picture.
Let the pictures talk….
Regards
niki
cutting-dado-hand-router-001.jpg  cutting-dado-hand-router-002.jpg  cutting-dado-hand-router-003.jpg  cutting-dado-hand-router-004.jpg  cutting-dado-hand-router-005.jpg
cutting-dado-hand-router-006.jpg  cutting-dado-hand-router-007.jpg  cutting-dado-hand-router-008.jpg  cutting-dado-hand-router-009.jpg  cutting-dado-hand-router-010.jpg
cutting-dado-hand-router-011.jpg  cutting-dado-hand-router-012.jpg  cutting-dado-hand-router-013.jpg  cutting-dado-hand-router-014.jpg  cutting-dado-hand-router-015.jpg
cutting-dado-hand-router-016.jpg  cutting-dado-hand-router-017.jpg  cutting-dado-hand-router-018.jpg  cutting-dado-hand-router-019.jpg  cutting-dado-hand-router-020.jpg
simplenik is offline   Top - Reply with Quote
Old 06-12-2006, 04:55 PM   #2
Gilbear
Supreme Forum King
Gilbear's Avatar
Gilbear is on a distinguished road
Hey Niki!
Looks like it works real nicely - thanks for sharing with us!
Seldom will a bit fit the actual width of your material - good work-around!
Gilbear is offline   Top - Reply with Quote
Old 06-12-2006, 05:23 PM   #3
simplenik
Forum Geek
Thank you Gilbear
I don’t like all the measuring and calculations around, I was looking (thinking) for some jig that will tell me; “your bit will cut here” and that’s the result, the cut is always on the knife mark.
I’m using the “knife mark” also for circular saw with the same precisian but we are in routers forum and...
niki
Old 06-12-2006, 08:28 PM   #4
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Just curious why your dado cut is so shallow? The common rule of thumb is half the material thickness. Also I was wondering if you have had any of these joints fail since the glue doesnt adhere well to the melamine?
Old 06-13-2006, 12:37 AM   #5
simplenik
Forum Geek
Hi Mike
I made this dado only as an example for the pictures.
As you noticed, the marking example was made on MDF and the actual routing on Melamine, I just used the melamine because of the good contrast for the pictures.
I never use dado connection in Melamine but Confitmat screws and sometimes dowels or both.
niki
Old 06-13-2006, 04:23 AM   #6
template tom
Forum King
hi Mike
Just to add my tuppence worth I always try for 1/3rd of the thickness of the upright material.
This adds greater strength to the material and prevents bowing should the shelf material be too tight
Strange how we all have different idea. Same with the mortice I always try for 1/3rd of the thickness of the stile only if the rail is the same thickness
Tom
Router Table Dado Jig RoyBullets Jigs and Fixtures 11 06-16-2008 08:41 PM
Cutting boards for gifts.... gad5264 Project Plans and How To 13 10-19-2007 11:13 AM
Cutting dados on a router table paulcomi Table-mounted Routing 6 08-05-2006 10:52 PM
Issues Cutting Dovetail Dados with Table Router Gazzalodi Table-mounted Routing 21 05-02-2006 10:40 PM
Routing a dado down the center garryjc Table-mounted Routing 13 10-05-2004 11:02 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
