Thread cutting jig using a router - Router Forums
post #1 of 19 (permalink) Old 05-19-2011, 04:11 PM Thread Starter
First Name: Julian
Has anyone seen or perhaps even made a jig that can cut threads in a wooden dowel? I recall seeing a book about routers jigs over a year ago that showed how this could be done but have not been able to located the book again.
JulianLech is offline
post #2 of 19 (permalink) Old 05-19-2011, 04:35 PM
Hi Julian
You can get them but I don't know of one for the router.
I have the set from 1/2" to 2" .
G1870 Wood Threading - 1" Die
Just a note ,take it back,,,I have seen a jig to do it with a router, I will dig around and if I find it I will post it.
The Router Crafter may do it also but I have not tried that, just need to make a fine index part for it..
The hard part would be the female part but that could be make on a lathe..
post #3 of 19 (permalink) Old 05-19-2011, 06:41 PM
Amazon.com: Beall Wood Threader Kit - Small: Home Improvement
John Schaben
jschaben is offline
post #4 of 19 (permalink) Old 05-19-2011, 06:48 PM
That's the one John,it's a fun toy
Video below
YouTube - ‪Wood Threader How To Part 1 You Tube‬‏
YouTube - ‪Wood Threader How To Part 2 You Tube‬‏
The Beall Tool Company
They don't show the drill bit that's needed ,it's not cheap..
for the 3/4-6 size ▼
Amazon.com: 5/8" Fractional Brad Point Bit: Home Improvement
Amazon.com: 3/4" Fractional Brad Point Bit: Home Improvement
Amazon.com: 7/8" Fractional Brad Point Bit: Home Improvement
The cheaper way ▼ but just as good
G1868 Wood Threading - 3/4" Die
Don't for get you may also need a bottom type tap.
http://www.woodcraft.com/Family/2000...ding-Kits.aspx
But you can buy the Beall tap that will do both jobs with one tap..(just remove the end of the tap) guide shelve.
http://cdn0.grizzly.com/manuals/g1869_m.pdf
Amazon.com: 20pc Deluxe Forstner Bit Set in Wood Case: Home Improvement
Amazon.com: 30 - Pc. Forstner / Spade Bit Set with Case: Home Improvement
YouTube - ‪Wood Threading Kits Presented by Woodcraft‬‏
How to Make a Wooden Nut Cracker ▼
YouTube - ‪Making a wooden nut cracker‬‏
Name:	nut cracker.jpg
post #5 of 19 (permalink) Old 05-19-2011, 08:06 PM
Looks like it Still need the tap for the internal threads, I assume.
John Schaben
jschaben is offline
post #6 of 19 (permalink) Old 05-19-2011, 08:13 PM
Hi John
Yep, no way around that I think...
post #7 of 19 (permalink) Old 05-20-2011, 07:17 AM
dutchman 46's Avatar
First Name: Howard
This may be the same one, but check it out anyway! http://www.newwoodworker.com/reviews/bealthrdrvu.html
John 3:16
dutchman 46 is offline
post #8 of 19 (permalink) Old 05-20-2011, 09:23 AM
bobbotron's Avatar
First Name: Rob
Lee valley makes a jig for doing this too.
Beall's Wood Tapping & Threading Kits - Lee Valley Tools
bobbotron is offline
post #9 of 19 (permalink) Old 05-20-2011, 11:04 AM
Ralph Barker's Avatar
First Name: Ralph
To cut threads on a dowel, there are at least a couple of approaches. The first (and traditional) method is the equivalent of a tap and die set - essentially the Beall and other brands that have been mentioned. Roy Underhill also did a segment on making one, years back.
The second approach is the equivalent of a machinist's milling machine, but using a router as the cutting tool. This requires a geared coordination of the rotation of the stock and the lateral movement of the router. ShopNotes magazine, in vol. 20 issue 115, showed such a router-based "mill" using a combination of wooden gears and an Acme-threaded rod for this purpose. With the right gearing, it could cut threads (outside/male), too, I suppose. One would still need a corresponding tap to cut the corresponding female threads, however.
ShopNotes Magazine - Woodworking Plans, Tips and Videos
- Ralph
Ralph Barker is offline
post #10 of 19 (permalink) Old 05-20-2011, 12:01 PM
Mike Wingate's Avatar
First Name: mike
I use the Beall system. I make my own dowels using a Patrick Spielman type box jig. feeding square stock into round hole with a router above, cutting off the corners. Great fun!
Mike Wingate is offline
Human Verification
New Router my way reible General Routing 20 11-30-2011 11:18 AM
New here burlboy Introductions 9 01-15-2009 11:53 AM
New Lower Priced Leigh Dovetail Jig scrollwolf Jigs and Fixtures 1 07-08-2007 05:10 PM
