| | #1 |
| Registered User New Member | Bought a Craftsman # 315.25791 because it had the 1/2 and 1/4 inch template. Did a nice job on the 1/2" but could not do a 1/4 because it calls for dovetail bit Catalog # 26319 for making the 1/4' dovetail. Unfortunately when I contact Sears they cannot find this bit and try to tell me any bit will work. NOT TRUE. I ordered a small bit from MLCS(3/8 width) but it is still to wide. The problem is it cuts the pins way to narrow. Does anyone know of a bit that will work? |
| | #2 |
| Forum Contributer Supreme Forum King | Hi raporter In order to cut 1/4" dovetails you need to use a 1/4" dovetail bit. But the stock should not be thicker than 1/2 thick. All the setting for the 1/2" will not work on a 1/4" dovetail and you will need to reset everything to cut the 1/4" dovetails. 1/4" dovetails are tricky to setup on most dovetail machines. ![]() The deeper the bit the tighter the fit...loose the goose is the best fit for 1/4" ,they break so quickly .Take a look at the url below ![]() C1510 1/4" 7° Dovetail Bit, 1/4" Shank http://www.grizzly.com/products/c1510 http://www.grizzly.com/catalog/2006/Main/438 Bj ![]() --------------- Just a NOTEs below Sears Craftsman # 315.25791 315.25710 below ▼ http://cgi.ebay.com/Dovetail-Jig-and...QQcmdZViewItem http://cgi.ebay.com/Sears-Craftsman-...QQcmdZViewItem Requires dovetail bit sears number 26318
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 09-19-2006 at 04:52 PM. |
| | #3 |
| Registered User New Member | Thanks BobJ3. I sent another inquiry to Sears and they tell me that bit is no longer available. I just ordered it last month so you would think they would discontinue the jig if they are not going to make a bit that will do the job. The reason I want the 1/4" dovetails is I saw some boxes made using them and they really looked nice. |
| | #4 |
| Registered User Supreme Forum King | As Bob has stated, you only need a 1/4" bit. You stated you ordered a bit but it's width is 3/8", either you ordered the wrong bit or, someone sent you the wrong bit. A 1/4" is a 1/4".
__________________ Ken "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #5 |
| Forum Contributer Supreme Forum King | You're Welcome raporter I made a box or two using the 1/4" dovetails but I now use the Oak-Park Box jig it works so much better and you can do it the same way if you want (blind slot ) plus it holds just like the dovetails do. Bj ![]()
| | #6 | |
| Registered User New Member | Quote:
| | #7 |
| Registered User Supreme Forum King | When you get your new bit, post some pics of your project when you get it done. ![]() I'm a believer in sears tools however, lately, either you order a tool only to find out 'bout 2-3 weeks later it becomes obsolete. As times change, seems like their (sears), service changes... for the worse!!
| Keller Dovetail Jig bits-Where/How do I replace them? With what? | nicksorenson | Router Bits - Types and Usage | 7 | 06-08-2008 02:01 AM |
| dust extraction for craftsman routers | mjmpropman | General Routing | 0 | 04-23-2008 12:11 PM |
| Craftsman Professional Dovetail Jig | dutchie1979 | Guide Bushings and Templates | 5 | 02-26-2008 06:46 PM |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Porter Cable vs. Craftsman | rprice54 | Tools and Woodworking | 7 | 01-17-2006 11:16 PM |
