| | #1 |
| Registered User New Member | Is there a handy and adjustable jig for adding keyhole hanging slots to an prebuilt projects, like a Plate Display Shelf unit? |
| | #2 | |
| The Router Guys Forum King | Quote:
If the keyhole slot is the same everytime then you just need to make a pattern that works with a guide to cut the slot. Position the pattern then cut the slot. This is a good tip topic. I have two tips I am working on as we speak but will put this one in the que.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| | #3 | |
One: make sure the slot is deep enough in the wood to hold well and long enough so it cannot easily slip out. Two: if the shelf is long enough try to have 16" centers or multiples of 16” so you can mount to wall studs. Three: on smaller then 16 “ pieces I like to take a ¾” x ¾” piece of pine and tap a couple of nails thru it so the points just come out maybe a 1/16” at the spacing I want. Then I use the piece of pine to locate the holes on the work piece and on the wall so they all line up. Four: on pieces that are going to get only one hole make sure you have the balance point or they will never hang straight. I like to use my trim router because it light weight and handy for this sort of project. I made an L shaped plywood cutout that I clamp to the work piece. I use the one side of the L to run against and the other as a stop on the top-side (where the slot is not the hole on the work piece). Keep in mind the top of the slot is where the screw stops and the starting hole is not as critical. If you need more information before Rick gets his tip out let me know I will make a drawing or take a picture of my set-up. Ed | |
| | #4 |
| Registered User Forum Fanatic | You could also use a keyhole cutter if you want to make the same cut regularly. http://www.trendmachinery.co.uk/profinder/ Input C120 in the Order reference at the bottom of the page.
__________________ Dewy support team at Paltalk voice chat program |
| | #5 |
| Registered User New Member | The specific project in hand is an oak Plate Display Shelf a relative purchased at a craft booth in a Mall somewhere. Got it home and realized it only had picture hangers on the back... not very secure for displaying her plates. Asked me if I could put Key holes in it.. Since it's back edges are scrolled top and bottom, the only square I have to work with would be the shelf board mounted to the front, so likely would have to reference from there, with a spaced template to the back side for the Keyhole guide. I'm thinking this problem will not be unique, because I've seen this before. If the next shelf is of different size/shape, an adjustable jig would be a better tool than a single set-up jig. My smallest router is a PC690. From that I go to a Bosch 1618 - 2 hp. |
| | #6 | |
| Registered User New Member | No problem hanging it, just wanting a relatively universal jig tool to set matched keyholes in the back of differing size/shape premade decor shelves. Once key holes are cut, two hole center tranfers set in the keyholes will mark the wall with the aid of a level on the shelf and subsequent pressure to make the dimples in the wall. Sorry if I wasn't clear. Quote:
| | #7 |
| Registered User New Member | I make keyholes in bracket shelves and two piece (rightangle) shelves which I make - or store bought shelves on the table with a fence. For brackets - I have clamped stops for start, stop and return. For store bought or right angle shelves I mark on the top of the shelf (as it sits on the table for a cut on the bottom) and mark where I want the start and stop to be (one or two or more) I then use my laser sight on the piece to line up the start and lower the piece over the router, move to the stop and return to the start and lift it off. Then to the next spot. |
| | #8 |
| Registered User | "You could also use a keyhole cutter if you want to make the same cut regularly." Just wanted to let everyone know that some information is timeless. This was very helpful and just the tip I needed to hang some shelves I made for my g/f. Be well, G ![]() |
| | #9 |
| Forum Contributer Supreme Forum King | Hi G Just in case you don't have a key hole bit around a Dovetail bit works very well also. But it works best in the Horz. way not the Vert.way, that way you can side it to the right or left to get it to hang true..put in with a plunge router... 1/2" O.D. 18 deg. works very well..and a 1/2" O.D. 14 deg. works well in a pinch.. http://www.mlcswoodworking.com/shops...s/bt_dove.html http://www.cmtusa.com/store/index1.i...routerbits.jpg ================
__________________ Bj Last edited by bobj3; 01-20-2008 at 12:07 AM. |
| Shelf pin hole jig - reviews and router solution | Greg_R | Jigs and Fixtures | 7 | 12-30-2007 06:18 PM |
| Which hole pattern should I get (plate for a Bosch 1617)? | Nickbee | Table-mounted Routing | 1 | 11-23-2007 06:49 PM |
| Room divider finished | jigger | Jiggers Gallery | 9 | 07-25-2007 01:29 AM |
| Drilling large hole over small hole or vice-versa | simplenik | Tools and Woodworking | 8 | 06-13-2007 07:57 PM |
| Routing a hole | Learning Herb | Tools and Woodworking | 11 | 03-20-2006 04:29 PM |
