| | #11 |
| Registered User Jr. Member | hey I appreciate you guys for your help... |
| | #12 |
| Registered User Forum King | What was not made clear at the beginning a Sliding Dovetail is required and from what I see in the pics it is produced on the router table. Has anyone used this method this before?? I do believe this could be done with the aid of the template guides with greater safety. I have produced the same sliding dovetail in a three legged table with a circular column to take three legs. Also a square column which is much easier. I have also joined rails to the leg of a table at 45 degrees again with the aid of the template guides. Tom |
| | #13 | |
| Registered User Forum King | Quote:
Tom | |
| | #14 |
| Forum Contributer Supreme Forum King | Hi Tom Thanks Can you please post the jig (template) you use to make the PIN and cut the pin on a 45deg. with a rounded end plus how deep to you set the dovetail bit when you only use 3/4" wide stock and how deep to you cut the slot to hold it. (the norm would be 3/8"deep) looks like 1/4" in the snapshot/picture ,true ?,,also a bit light on the stock on the end of the cut,looks like it almost went to far,true ?. Thanks Bj ![]()
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 11-02-2006 at 08:15 PM. |
| | #15 | |
When using 19mm material i made a 4mm cut 3/8ths would be halve way. The position requires to be changed so that the dovetail is more central. Still working on the drawings Tom | |
| mortises in queen anne leg | frankbyrne | Starting Off | 3 | 03-01-2008 09:26 PM |
| Table Legs | bobj3 | Jigs and Fixtures | 4 | 06-05-2007 09:29 PM |
| Folding table legs | Qstick | Tools and Woodworking | 13 | 02-24-2007 01:05 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 12:02 PM |
| jig for turning round legs. | heisnerd | Jigs and Fixtures | 1 | 10-05-2004 03:04 PM |
