| | #1 |
| Registered User New Member | Request a simple free plan for a homemade box joint jig for a router table. Thanks gman |
| | #2 |
| Forum Contributer Supreme Forum King | Hi gman You can make one quick and easy, just use the link below to see how to make the best on the market. ![]() Box jigs ▼ http://us.oak-park.com/catalogue.html?list=boxj-- How to use the box jig below ▼ http://www.routerworkshop.com/boxjoints.html ----------------- Push block for the Oak-Park Box jig ▼ http://www.routerforums.com/jigs-fix...ght=push+block ----------------- But for the price of the Oak-Park box jig you may want to just buy one that will work every time. ![]() They are great jigs and true, you will need to take my word for it ![]() Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 11-30-2006 at 10:23 AM. |
| | #3 |
| Registered User New Member | Hi, New to the router forum. I would like to know how to make a box joint jig. Thanks, Benny benny-cotton@ouhsc.edu |
| | #4 |
| Forum Contributer Supreme Forum King | Hi Ben For the router table Start with some 1/2" MDF or Plastic stock,put a 1/4" slot down the right side,about 2 1/2" from the edge, put in a 1/4"wide slot 3/8" deep,then cut a spline from some 1/4" MDF or plastic (1/4" x 1/2" tall ) and glue it in the jig,sand down the edge so the stock can move free over the spline,but not to free. ![]() For the Free Hand Plunge router. This is a real hard one to make because it needs to be dead on. ![]() This will take a band saw or a good jig saw. To make the template use some 1/2" MDF or plastic, the slots will need to be 1/2" wide so you can use a brass guide or a bit with a bearing on the bit. This will let you use the template over and over without turning the template into firewood. Now ask a mate if you can use his 1/4" template as a pattern to make yours,it can be a Alum.one or the plastic type from PC,HF,Rockler,etc. just about any of them will work to make yours. You can try a make one from sq.1 but it will not turn out right because it needs to be DEAD ON ,once you have the pattern cut it out (WITH CARE ) again it must be dead on, one miss cut and it's junk, .010 is a big deal when it comes to box joints because they must match when you try to put them together. Once you have the template made mount it to some 2" x 6" stock so you clamp it to the bench top ( L type bracket made with 2ea. 2" X 6" stock) Then drop in a bit in you plunge router and make a pass on two boards and test fit them after you make them. Good Luck Bj ![]()
| Box joint - first attempt | Dennis Davis | Show N' Tell | 5 | 02-09-2008 10:01 PM |
| Incra half blind joint | S Bolton | Jigs and Fixtures | 7 | 10-23-2007 02:38 PM |
| Hidden Mitre Joint | DougO | Router Bits - Types and Usage | 9 | 10-21-2007 12:42 AM |
| My first finger joint box | simplenik | Table-mounted Routing | 6 | 06-24-2007 09:52 AM |
| My first ever Finger (box) joint | simplenik | Table-mounted Routing | 19 | 06-23-2007 10:53 AM |
