Small Discs Jig - Router Forums
post #1 of 17 (permalink) Old 07-08-2012, 07:02 AM Thread Starter
First Name: Will
Default Small Discs Jig
I want to create small discs of various sizes. Absolutely round,3/4" thich, smooth edges for gluing. I remember seeing a v-block jig for rounding a rough cut discs, but unable to relocate details re jig use. Pros and cons are welcome. I want to gather more info before using this method.
Assistance is always appreciated.
prospector45 is offline
post #2 of 17 (permalink) Old 07-08-2012, 07:48 AM
Firstly Will, welcome to the forum.
When you say "small discs of various sizes", what sizes are you talking about.
You could use a template or circle jig to cut the discs. They would not be "rough cut" and would need little smoothing.
How do you intend to glue them? On edge? side by side?
Sydney, Australia
jw2170 is offline
post #3 of 17 (permalink) Old 07-08-2012, 09:23 AM Thread Starter
First Name: Will
Thanks for the welcome. I want to make a serving board with different widths of differnet woods. When this is glued together, I then want to route a circle through the wood board. At this time I want to use a Disc near the thickness of the board, cut it in half, taper the edges and then use as a "plug" to fill the hole from both siges of the board. This will give the appearance of the "plug" being a solid piece of wood.
the tapered egdes will allow a very snug fit into the hole.
Does this make sense?? The hole in the board and the corrresponding "plug" could be of different sizes relating to the visual aspects of the entire board.
Will
Assistance is alwasy appreciated.
post #4 of 17 (permalink) Old 07-08-2012, 09:34 PM
First Name: Mal
Apart from wanting to cut right through the board, it sounds like you want to achieve an inlay effect. For my money, I would settle of going the inlay route, working from each side but cutting and inlaying a maximum of 1/8in deep.
To do this you need a home made template for the patterns you want, and an inlay kit. The kit included a small bit (typically 1/8in) a template guide, and a spacer that fixes onto the template guide. Many suppliers produce the kits and most have web videos on using them.
In use you cut the recess and the inlay piece using the same template, and adding or removing the spacer to the template guide ensures that the inlay and recess match, unless you have sharp corners, where the recess will have a corner radius equal to the bit radius. In that instance you can trim the corners of the recess, or round the corners of the inlay to match. Here is a link to a video explaining the method.
If you make the master template reversible, you should be able to get a very close match for the inlays so it looks as though the go right through the board. Hope this helps you.
malb is offline
post #5 of 17 (permalink) Old 07-08-2012, 10:41 PM
Trend Pivot Frame Jig - YouTube
Amazon.com: Trend PFJ/SET/1 Pivot Frame Jig Set: Home Improvement
post #6 of 17 (permalink) Old 07-09-2012, 01:22 PM
Santé's Avatar
Country: Belgium
First Name: Daniel
Hello
This jig will help you:
Techniques
PDF file at : http://www.lescopeaux.asso.fr/Techni...te_Tripode.pdf
Cheers
Member of the french site for woodworkers
Santé is offline
post #7 of 17 (permalink) Old 07-09-2012, 06:32 PM
CharleyL's Avatar
First Name: Charley
For cutting the tapered plugs you might want to consider these
Woodworker.com: Patented Rtss-2000153 Stubby Plug Cutters Use Compound Radial Taper To Cut Short Plugs That Fit, Set - Rtss Plug Cutter Set Of Three
They could then be driven into drilled holes (with glue) from both sides and the excess trimmed off.
Charley
Central North Carolina
CharleyL is offline
post #8 of 17 (permalink) Old 07-14-2012, 02:15 PM
Simple way to cut disks. You just need to cut template first with hole jig.
Regards;
Name:	Picture 011_1.jpg
giltic is offline
post #9 of 17 (permalink) Old 07-16-2012, 07:24 AM Thread Starter
First Name: Will
The inlay technique provides more options for varying the pattern. One could have cherry on one side and say, walnut on the other. Would be a neat appearance.
post #10 of 17 (permalink) Old 07-16-2012, 07:25 AM Thread Starter
First Name: Will
This in one neat tool accessory. Thanks
Human Verification
Dovetail Jig Tip jlord Jigs and Fixtures 4 11-04-2011 10:20 AM
Small Parts Jig RLFX Jigs and Fixtures 73 03-27-2011 06:55 PM
What is this jig? crquack Jigs and Fixtures 15 12-16-2008 08:16 PM
question Henry Fernandez Starting Off 14 02-11-2008 05:46 PM
