| | #1 |
| Forum Moderator Supreme Forum King | I would like to know if there is some kind of holder to make so that I can take square stock and use a round over bit to round the wood enough to make walking canes Thanks ![]() |
| | #2 |
| Forum Administrator Supreme Forum King Join Date: Aug 2004 Location: Winnipeg, Manitoba, Canada First Name: Mark Posts: 3,787 ![]() | I believe but I'm not sure, but the tool that you usually use for that type of project would be a lathe. The lathe will spin the block of wood at high speed and you'll use the hand tools and shave the wood off. ![]() If you don't have a lathe, or your not looking to buy one. I'm sure you could use a stick of dowel and round over the ends. I'm no really sure if a router can do such an operation, but it could be possible. Tommorrow I'll get a confirmed answer from Bob or Rick. Hope this helps .
__________________ Mark, Administrator and Technician of RouterForums.com RouterWorkshop.net - Get more out of your router! |
| | #3 |
| Forum Moderator Supreme Forum King | I thought being some where I saw an article that you can use a router for dowels that maybe there is a way to make round stock |
| | #4 | |
| Registered User New Member | Quote:
| | #5 | |
| Registered User Jr. Member | Quote:
| | #6 |
| Forum Administrator Supreme Forum King Join Date: Aug 2004 Location: Winnipeg, Manitoba, Canada First Name: Mark Posts: 3,787 ![]() | That sounsd pretty cool, I think a router lathe would be a pretty interesting concept.
| | #7 |
| Router King Supreme Forum King | You can use a bullnose bit in a table mounted router in two passes. Leave enough of the square end to support the piece. I just made a 3/4 round mahogany handle for a pen press using a roundover bit. Takes four passes but the results were good. IMO the round stock has to be done with a table mounted router for best results. |
| | #8 |
| Forum Moderator Supreme Forum King | Thanks I'll give it a try all I have though is a round over bit so I make 4 pass instead of 1 pass. When I get around to it I'll tell everyone how it came out. |
| | #9 | |
If that's outside your price range: Use a hole saw to make 2 wooden wheels - the same size (slightly larger than your square stock) if you want to round a dowel (or of different sizes if you are going to make a taper). Drill holes in the exact centers of each end of your stock to take a screw. Screw the wheels onto your stock. You then adjust your fence so the stock is centered over the bit. Raise the bit to the initial position, start the router and gently feed the stock, rotating and feeding right to left. For a cane size dowel or taper you will need an auxiliary top to your router bench about twice as long as the dowel/taper you are cutting.
__________________ Jerry "The Dinosaur" Mings Moola Invitation "Après moi, le déluge." -Louis XV "Arbeit Macht Frei" - Lieing legend above the gates of German concentration camps. | |
| | #10 |
| Forum Contributer Supreme Forum King | Just more on cane making ![]() http://www.routerforums.com/show-n-tell/1468-canes.html Poor man's Lathe Attachment for Drill Press, it can also be used of the floor model drill press. http://www.grizzly.com/products/Lath...ll-Press/H8071 Here's a tip you can buy dowel rod stock from 1/16" to 3" diam. and from 12" long to 10ft. long...in many types of wood stock...... ============
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 03-11-2008 at 01:04 AM. |
| Setup for Puzzle Making | rstermer | Jigs and Fixtures | 0 | 05-29-2008 05:23 PM |
| Making a vase part 1 | chippypah | Woodturning and Lathes | 0 | 03-04-2008 03:23 AM |
| Wooden sign making | tigger | Introductions | 5 | 08-16-2007 06:31 PM |
| Door making sets | Hat | Router Bits - Types and Usage | 6 | 11-09-2006 08:13 PM |
| template making wood | reds_21 | Tools and Woodworking | 3 | 07-10-2005 09:45 AM |
