Thread Tools Display Modes
Old 03-17-2007, 04:26 PM   #1
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Default Finally Got The Gifkins Set Up.....
Well today I took a break from the kitchen and decided to get the Gifkin set up.
It's as easy as the Demo makes it. The Gifking cuts the dovetails on one side of the jig and the slots on the otherside. You set the stock block by centering the work piece over the pins so it looks good and that is all you have to do.
Once you have that then set the height of the dovetail cutter. I set it a little proud of the boards thickness. See photo 2
I then cut the dovetails. Then you flip the workpiece to the straight cutter side and change to the straight cutter, set the height of the cutter again and cut the slots. The Gifkin uses paper shims on the straight cutter side. Each template comes with 5 shims in the jig. For a tight joint you add shims to loosen and remove shims to tighten. Mine was just a tad tight so I added a shim and recut the slots. This time I got a great fit just right for a glue joint.
I then marked the backer boards that it was 6 shims for the A-10 template. I designated these backer boards for 7/16 stock. The jig is now set up for the A-10 template and doesn't need set up again unless you change to another template. You don't have to designate backer boards to certain sizes of stock but I have for 7/16, 1/2 and 3/8 stock.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 03-17-2007, 04:47 PM   #2
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
Can it do 1 inch thick wood or limited to 3/4" ?
router è ancora il mio nome
Router is still my name is offline   Top - Reply with Quote
Old 03-17-2007, 05:14 PM   #3
challagan
Supreme Forum King
challagan's Avatar
Hey Router. This particular template is for up to 1/2 material. Another template allows up to 3/4. This jig is designed particularly for box work. Roger Gifkin is a master box maker so that is what he designed it for. You can make smaller drawers with it and there is a template that allows up to 300mm wide material for a blanket chest but in my opinion it would be unstable on the router table. It's best doing what it is designed for, thin wood box work.
Old 03-17-2007, 05:24 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Corey
Looking Good, nice jig
You may want to send off for the bit set below, they work in my setup and I'm sure they wil work in your new Gifkins jig as well, the small one in the set will let you do 3/16" -1/4" thick stock or to say put in 11/32" wide dovetails.
http://cgi.ebay.com/5pc-Top-Bearing-...QQcmdZViewItem
I did pickup two sets because of the great price on them.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 03-17-2007, 07:30 PM   #5
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Alright Corey..... back to the kitchen for you! You posted this just to make me green with envy because you know Gifkin won't arrive for another 3 weeks yet. Nothing wrong with being green on St. Paddy's day, but this is not what I in mind.
I can't wait for it to get here, it appears to be the cat's meow. Those are some great looking dovetails in those pictures. Very tight and slightly proud.... picture perfect!
Don't guess I could borrow yours until mine arrives?
Cheers,
Bob
Bob is offline   Top - Reply with Quote
Old 03-17-2007, 10:54 PM   #6
challagan
Supreme Forum King
challagan's Avatar
Hi Bob, thanks for the link! That reminds me, I need to get some of those little rubber ORings so that if the grub screw becomes loose it doesn't ruin the template. What size of O ring do I buy for 1/4 inch shank?
Old 03-17-2007, 10:58 PM   #7
challagan
Supreme Forum King
challagan's Avatar
Sure you can borrow it. Come and get it anytime Hey Bob, forgot to mention this. You want to be sure those little grub screws are tight on the collars that hold up the bearing. If that works loose the collar drops and that means the bearing drops and then you have a problem cause if the bearing ends up below the template, your going to chew it up and ruin it. Bobj mentioned this to me before and today when I was removing the bit from the router and the collar dropped down cause the grub screw was loose Bobj uses a little O ring on the shank under the collar to hold it up if the grub screw fails. Good insurance. Just wanted to mention that.
Cpreu
Old 03-17-2007, 11:40 PM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Corey
If you don't have any Oil Rings the right size you can put on some black elec.tape just under the lock collar,2 or 3 raps will do it.note the way you rap it on you don't want it to unrap.
I cut the tape into 1/4" wide strips.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 03-18-2007, 08:58 AM   #9
del schisler
Forum Geek
del schisler is on a distinguished road
I have that gifkins dovel tail for a couple yr's now I use 2 router's and 2 tables One for the dovel tail's And the other for the pin's Sure work's very well I have made over 50 jewely box's and lot's of drawer's I know you will like it Once you get the width of the board cut So that it come's out right With enough on the ends for the pins and tails del
del schisler
del schisler is offline   Top - Reply with Quote
Old 03-18-2007, 09:58 AM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Corey
"What size of O ring do I buy for 1/4 inch shank? "
3/16" ID, then roll them on, they are like you know what, you don't want them to COME off or Side down at the wrong time. .
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
I finally have time RGOSSEL Introductions 4 03-06-2008 08:31 PM
Router bits for Gifkins S Bolton Jigs and Fixtures 9 12-20-2007 10:12 PM
Finally .. Finally.... challagan Table-mounted Routing 6 12-05-2007 01:06 AM
Katie Jig vs. Gifkins S Bolton Jigs and Fixtures 14 11-27-2007 10:34 PM
Gifkins vs. Incra S Bolton Jigs and Fixtures 27 08-12-2007 08:05 PM
