Details of Dado jig please?
This is a discussion on Details of Dado jig please? within the Jigs and Fixtures forums, part of the Routers category; Okay, I have my 1" cutter and brass template guide set. Am ready to make ...
Old 03-28-2007, 05:43 AM   #1 (permalink)
First Name: Fatz
Birch is on a distinguished road
Default Details of Dado jig please?
Report Post Report This Post!
Okay, I have my 1" cutter and brass template guide set. Am ready to make my dado jig. I have the photos Bob3 posted some time back. But I am not clear on how the jig is completed on the ends? Hard to phrase this question. But, okay....we have the long narrow piece with the 1" wide slot in it. Got that. But what is at each end? and how thick? Does it sit ON the work piece? I have a jig I've been using, the type where the router rides between the "rails", so to speak and it works okay. I goes OVER the work piece etc. Sorry guys, but I am just having trouble grasping the thing, even with the photos. I remember when the "single slot" plan was first posted I thought it was a GREAT idea and still do. I can DO dados with what I have, but the single slot appears to be much simpler AND probably more accurate. Thanks.
Birch is offline
Old 03-28-2007, 09:13 AM   #2 (permalink)
bobj3's Avatar
First Name: Jigs
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Birch
This may help, see drawing below ▼
Bj
http://www.routerforums.com/jigs-fix...ge-router.html
How To Install a Router Base Plate
http://www.popularwoodworking.com/ar...e_plate_video/
Find owner's manuals
http://www.managemyhome.com/
Bob J.
Old 03-29-2007, 05:29 AM   #3 (permalink)
First Name: Fatz
Thank you very much. That is precisely what I needed. And I had not thought about a "starter" pocket for the straight bit to get a grip. Will keep you posted. Appreciate the assistance.
Birch is offline
Old 03-29-2007, 08:54 AM   #4 (permalink)
bobj3's Avatar
First Name: Jigs
You'er Welcome Birch
Bj
Bob J.
Old 04-24-2007, 08:11 AM   #5 (permalink)
cabinetman's Avatar
cabinetman is on a distinguished road
This jig is basically a "T" square you make yourself. This one will accommodate a 4' dadoe. The first pass puts into the jig the exact groove. When inserting the panel, simply put mark on panel line up with groove, and set bar clamp so that the top bracket touches the right leg to keep it from moving. I've used this type of jig for over 30 years and it's a very fast set-up. It's accurate as all heck. Can do long or short runs. The panel in the picture is 18" x 18".
cabinetman is offline
Old 04-24-2007, 11:10 AM   #6 (permalink)
Banned
Joe Lyddon's Avatar
Joe Lyddon will become famous soon enough
Cool
Cabinetman - Mike,
That's a COOL jig!!
It took me awhile to GET the clamp procedure... then it hit me... you're just clamping the workpiece to the crosspiece of the T square!! Ingenius!!
I was thinking that a cabinet clamp like a Jorgy or Bessy might be easier to use... AND a piece of backerboard could be placed over the far end of the workpiece (where clamped) to reduce tearout... Yes? What do you think?
Does the router you're using have a square base to be sure it guides 'straight' along the jig side? ... or is your round base uniformly centered making it accurate in case the router got turned on the way across the cut?
I LIKE your jig!!
The NICE part being "line it up and cut" feature... saving time & being accurate! ... to say nothing about the unique way of clamping it!!
Do I have your permission to add it to my web page 'collection'?
Thank you...
Joe Lyddon is offline
Old 04-24-2007, 11:46 AM   #7 (permalink)
cabinetman's Avatar
It's very quick and really easy. I just got used to a bar clamp. They don't seem too bend under 5' long. A scrap piece at the head of the subject would help for tearout. I use a round base. Get kinda used to which way to hold the handles, and actually it's very centered. I usually leave one router with the bit that I used for the initial run that put in the first groove in the "T" part, set up just for dadoes with this jig.
Old 04-26-2007, 11:11 PM   #8 (permalink)
Banned
Joe Lyddon's Avatar
Cool
Cabinetman, Mike,
Per your permission, I have added this router dado jig to my website collection...
Under "Jointery"
http://www.woodworkstuff.net/CabManRteDadoJig.html
... and I have reorganized the Jig & Tool page...
http://www.woodworkstuff.net/woodidxjigs.html
Hope you like it...
Thank you...
Old 04-27-2007, 12:00 AM   #9 (permalink)
challagan's Avatar
challagan is on a distinguished road
Cabman's jig is one I built and I first saw this as one of Norm's jigs he used a lot. I need to make a new one! Of course this would be a non adjustable jig or in other words it won't work well with plywood due to the ever changing thickness of plywood. You really need an adjustable dado guide for that.
http://iowacarver.tripod.com/
challagan is offline
Old 04-27-2007, 10:59 AM   #10 (permalink)
Banned
Joe Lyddon's Avatar
I was going to make mine for a 1/2" bit...
I would use target piece to mark the actual width... then, make two passes...
One lined up on the left mark... then on the right mark...
I was going to try it... I think it would work... do you?
Dado Jig for Plunge Router bobj3 Jigs and Fixtures 20 03-07-2009 02:44 PM
Router Table Dado Jig RoyBullets Jigs and Fixtures 11 06-16-2008 08:41 PM
FREUD Dado Sets sawstop Tools and Woodworking 4 10-30-2006 03:57 PM
Router Adjustable Dado Jig Barry_White Jigs and Fixtures 4 02-07-2005 01:17 AM
Dado blades and other table saw specialties Mike Tools and Woodworking 3 01-05-2005 08:07 PM
