PC 4216 or MLCS master joinery set - Router Forums
post #1 of 8 (permalink) Old 12-11-2013, 11:32 AM Thread Starter
donald_archer's Avatar
First Name: Don
I am seriously thinking about buying a dovetail jig. There are a couple of deal breakers. First, it must be easy to use(or relatively easy) and it must be able to make a wide variety of joints(half blind, through, rabbeted and finger/box) because I do not want to have to by each template ad hoc. I want to buy the thing once and be done with it
Any recommendations, suggestions, comments, warnings or such?
thanks in advance
Don
"I have never made a mistake. I just make lots of Prototypes"
donald_archer is offline
post #2 of 8 (permalink) Old 12-12-2013, 06:27 AM
Country: Brazil
First Name: ClŠudio
Why do not Incra.
P1160001 - YouTube
http://www.routerforums.com/jigs-fix...etail-jig.html
Botelho007 is offline
post #3 of 8 (permalink) Old 12-12-2013, 08:08 AM
I have both the 4216 and an Incra ultralite, not so sure I'd go with the Incra for anything else but the 'little' stuff.
For any project calling for a production run with larger pieces, the PC would be my go to jig.
To the OP question, best bet would be the check out the specs on both as far as what is included and capabilities. I have no experience with the MLCS rig but I like the cam locking system on the PC so all else being equal that would be my 'deal maker'
TomE is offline
post #4 of 8 (permalink) Old 12-12-2013, 08:38 AM
Shortslvs's Avatar
First Name: Fred
Claudio that jig was great. Exactly what I need to add to my Incra system. Was that yours or do you have a link to that plan. Looks as though the jig is used for much more than the youtube video showed.
Thanks,
Fred
Shortslvs is offline
post #5 of 8 (permalink) Old 12-12-2013, 08:42 AM
Shortslvs's Avatar
First Name: Fred
Never mind I got another look and I think I got it figured out. Great jig!
post #6 of 8 (permalink) Old 12-12-2013, 08:58 AM
Country: Brazil
First Name: ClŠudio
Hi, Fred the video is of the Rembo.
You can contact you by PM:
Rembo @ LumberJocks.com ~ woodworking community
post #7 of 8 (permalink) Old 12-12-2013, 09:32 AM
CharleyL's Avatar
First Name: Charley
Don,
You are asking for something that really doesn't exist yet, except for a CNC Router. A CNC router can do it all, but it's cost will likely exceed the cost of the rest of your shop. There is a very steep learning curve as well.
Your desire to have only one jig that will do all of what you want requires a jig with a lot of adjustments/variables that will complicate the jig. In my opinion, the best jig that will do what you are asking is the Leigh D4R Pro. It does an excellent job, and the manual and DVD for it are the best in the business. But, because of all of these features, it can require a refresher to re-learn the features that you need each time you are about to put it back into use. Still, it will do what you ask of it and do it very well, if you follow the instructions and set it up correctly.
If you are willing to accept a dovetail jig that lets you to just make dovetails and you want simplicity, then the Katie jig is probably your best choice, because it needs almost no adjustments. However, it can't do anything but dovetails.
Box joint jigs can run from the very simple that only make one size joint or the more complex adjustable jig that can make multiple sized joints. Most of these are simple in design but can be difficult to set up correctly. For a fixed and variable spaced box joint jig that is quite easy to set up, the Incra I-Box jig is very accurate and relatively easy to use. The manual and DVD for it are also very good and the I-Box jig can be used on either a router table or on a table saw.
I own both the Leigh D4R Pro and the I-Box jig, and I once owned the Katie Jig. All of these jigs will do what their instructions and advertising say they will do, and do it very well, if you set them up correctly.
Charley
Central North Carolina
CharleyL is offline
post #8 of 8 (permalink) Old 12-12-2013, 11:18 AM
Hi
Just a note the Katie jig can do Box joints,blind dovetails,normal dovetails,for the blind dovetails you need the bit below..and a FIXED template..
Ovolo Bits 7/8"CR,2-1/4"CD,1/2"SH
http://www.mlcswoodworking.com/shops...light=faux+bit
Sommerfeld's Tools for Wood - Dovetails Made Easy with Marc Sommerfeld - Part 1 - YouTube
Originally Posted by CharleyL View Post
Don,
Charley
Name:	101 dovetail.jpg
Human Verification
JessEm Master R Lift Excel Repair Model #02201 TRN_Diesel Tools and Woodworking 7 09-12-2013 04:59 PM
Elite Tools 66 PC Router Bit Master Set 1/2" Shank Racer2007 Router Bits - Types and Usage 19 01-10-2011 06:39 PM
help picking first router bit set... blurry Router Bits - Types and Usage 2 01-21-2009 09:48 PM
I think I settled on a starter bit set. Any C&C? Skyglider Router Bits - Types and Usage 40 12-28-2008 09:23 PM
Hickory Woodworking RBK1030 24-Piece Carbide Master 1/4" Set for 26.99 w/ free ship evolve The Bargain Bin 1 04-21-2006 01:40 AM
