| | #1 |
| Registered User New Member | I hope Swann is on his way with the PC Hinge Jig. I have one and I think it has great possibilities if I ever get to use it! Let me explain... I've been a general handyman for over 50 years but occasionally something stumps me. I recently acquired a Porter Cable Hinge Butt Jig #59280 for doing some door installations. It's main advantage is once it's setup you can route the mortises on the door and the jamb with the same setup and everything matches perfectly. The downside is the template guide that it requires is PC 1-3/16", a Porter Cable standard also used by several other makers. Unfortunately, my Hitachi TR-8 is not one of the compatible ones. My choices seem to be find an adapter or buy a new router. As much as I would like to, a new router is too much strain on the budget. With all the expertise that must be available on this forum there must be at least one solution out there. I don't want to return the jig because it is exactly the right tool for the job. I've built my own hinge jigs at various times and they work for a given situation but they are a one-shot deal. The next door is always different or the hinge is different or something. Enough! I now have a jig that will do it all if I can find a way to use it. Suggestions, anyone? |
| | #2 |
| Forum Contributer Supreme Forum King | Hi tiredbones Take a look at the link below and the snapshot Bj ![]() 10 PC ROUTER TEMPLATE GUIDE SET You may need to drill the holes in the brass apt.to mount it to your router. http://www.harborfreight.com/cpi/cta...emnumber=95160 will fit Hitachi models: M8, M8V, TR8,TR12, M12SA, M12V. ▼ http://item.express.ebay.com/Industr...mdZExpressItem OR can go this way ▼ http://froogle.google.com/froogle?q=...R8&btnG=Search
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 04-12-2007 at 07:55 PM. |
| | #3 |
| Registered User Forum Geek | Hi, Tiredbones. PC guides are all 1 3/16ths. but what is the required guide to do the job? 5/8ths 1/2" . Oak-Park sells 7 inch square base plates if you get one that fits your TR 8, you could use the Oak Park guide and ring nut. They are 1 1/2" but you can buy just the size guide that you need . ie 5/8 ths 1/2" etc. Hope this helps. Woodnut65 |
| | #4 |
| Registered User New Member | Hi, Woodnut65, The required guide IS a PC guide, 1-3/16, but it's extra long to reach all the guiding surfaces in their rather deep jig. As you probably know, a PC guide bushing fits an Oak Park base like a BB fits a basketball hoop. A simple solution, if Oak Park were amenable, is to machine a reducing bushing with an external 1-1/2 thread and internal 1-3/16 thread. If I had a lathe I would do just that. It's not a difficult problem. It would have the added advantage of making the Oak Park bases able to accept the rest of the world's guide bushings especially these special purpose ones. One can only hope... TB |
| | #5 |
| Registered User Forum Geek | Hi TB: Would the adapter in the set of guides that BJ shows do any good for your problem? I have that set of guides with that adapter and I have no use for it. Where abouts are you located? Maybe I could mail it to you. Woodnut65 |
| | #6 |
| Registered User New Member | Hi WN: I'm not sure about that adapter. It could have possibilities but I don't get the four holes. It might be worth a try. It would help to see it installed. I'll email you an address. TB |
| | #7 |
| Forum Contributer Supreme Forum King | Hi TB Go back 4 post up ▲ and you will see it installed. also see the eBay link same post ![]() The four holes are for other types of routers Bj ![]()
| | #8 |
| Registered User New Member | Sorry, BJ, I didn't notice the adapter mounted in that router. That looks like it might work. Thanks, TB |
| | #9 |
| Forum Contributer Supreme Forum King | Hi TB You didn't miss it I just added it when you said you wanted to see it mounted. ![]() Plus the link for the ebay item, it shows your router as one that can use it. Bj ![]()
| Problem with porter cable dovetail jig | ldsmith1234 | Introductions | 4 | 02-12-2008 07:51 PM |
| router raising problem | Don G | Introductions | 6 | 10-16-2007 12:03 PM |
| Problem with my Hitachi M12V | Visteonguy | Table-mounted Routing | 23 | 08-19-2005 12:22 AM |
| elu router problem | fretbender | Portable Routing | 7 | 03-21-2005 11:35 PM |
| Hitachi M12V Router Problem | dcarriere | Tools and Woodworking | 3 | 12-28-2004 07:50 AM |
