Thread Tools Display Modes
Old 11-16-2004, 12:12 PM   #11
reible
Supreme Forum King
reible's Avatar
Originally Posted by old rebel
The stock to be cut is simply held by hand on the guide pin and fence. See the picture of this at http://store.yahoo.com/plansnow/boxjoint.html . The jigs I used before building this one were of the "fixed" pin type probably similar to the ones you describe. I still use them if I want a different size box joint, but this one looked really neat with all it's fancy micro adjustments and I thought it might be more versatile. Mostly I use the 1/4" box joint for about every thing i need to do.
Thanks again
On a table saw the parts can be handheld as shown but with a router the bit will try and move the part and as you have said it bends the metal. For router use you will have to clamp it and maybe add some sandpaper to the jig to help hold the wood in place. That will slow down the process but if you get a quick acting clamp it might not be to bad. The closer you clamp to the cutter the better.
I have a miter gauge that has the same general features of the jig but I still use the hand made ones....
I hope this helped.
Ed
Old 03-26-2008, 10:48 PM   #12
john_29
john_29 is on a distinguished road
Exclamation finger joints
Question;;Were interested in engineered wooden beams.Do you have a tool
or jig to use on our router or wood shaper to join (end to end) 1x6
lumber?Also,we'd like the same for side by side lumber.
Godbless,
John Higgins
Camiguin,Philippines
john_29 is offline   Top - Reply with Quote
Old 03-26-2008, 11:21 PM   #13
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi John
End of the boards would be the one below
Finger Joint Router Bit
http://www.mlcswoodworking.com/shops...r_joint_anchor
http://www.grizzly.com/products/Shap...3-4-Bore/C2124
T & G bits on this page should do the job for the side by side
http://www.mlcswoodworking.com/shops...ue_groove.html
http://www.grizzly.com/products/Shap...1-2-Bore/C2310
http://www.grizzly.com/products/C2028
http://www.grizzly.com/products/C2029
Godbless,
John Higgins
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Bj's box joint jig steveo Jigs and Fixtures 1 02-12-2008 08:49 PM
Incra half blind joint S Bolton Jigs and Fixtures 7 10-23-2007 02:38 PM
Hidden Mitre Joint DougO Router Bits - Types and Usage 9 10-21-2007 12:42 AM
My first finger joint box simplenik Table-mounted Routing 6 06-24-2007 09:52 AM
