Thread Tools Display Modes
Old 11-15-2004, 11:17 AM   #1
old rebel
New Member
old rebel is on a distinguished road
Default Box Joint Jig from "ShopNotes" Magazine
I recently built the box joint jig shown in ShopNotes Magazine Issue #8 and could never get it to work exactly right as designed.
The problem was with the angle bracket "adjustable key". Since it is made from soft steel mending plates and one end is floating unsupported, lateral pressure from the router bit forces the wood against it and pushes it out of alignment. No matter how I tried, I could not get a consistent fiting joint with it. I finally gave up and modified it to use a piece of 1/4" steel for the alignment pin. It is no longer adjustable, but it cuts nicely fitting 1/4" box joints now. I suppose if you wanted to use it on a table saw it might work OK as originally designed, but hey, I wanted it to work with the router table.
Has anyone else tried this jig or is there a better design out there somewhere?
Thanks,
old rebel
old rebel is offline   Top - Reply with Quote
Old 11-15-2004, 12:42 PM   #2
g-man
Dedicated Member
g-man's Avatar
g-man is on a distinguished road
Default Box joint jig
Check with Oak Park Enterprises. They have jigs. Because of price constraints, I make my own jigs.
http://www.oak-park.com/host_page.htm
g-man is offline   Top - Reply with Quote
Old 11-15-2004, 12:58 PM   #3
old rebel
New Member
I like to build my own also g-man ........
I guess I should have asked, "Has anyone out there BUILT a better jig than this one?"
Old 11-15-2004, 01:18 PM   #4
reible
Supreme Forum King
reible's Avatar
I don't know what the jig looks like but since you have spent time making it maybe if someone could post a picture "we" might be able to suggest a fix. Or maybe someone has already thought up one??????
Ed
Old 11-15-2004, 05:39 PM   #5
old rebel
New Member
Ed
Well I uploaded a couple of pictures as file attachments, but I don't see them. Could someone help me with that?
Old 11-15-2004, 06:16 PM   #6
reible
Supreme Forum King
reible's Avatar
Sure, the easy way is to use the Go Advanced button on the reply. Then attach them using the Manage Attachment button. When it comes up browse to the location of the pictures (they take bmp, jpg etc.) and when you have them appearing in the files to upload: hit the Upload button. You may need to reduce the size of the files to meet the requirements (97.7 KB). It takes a few seconds to upload (more on slower links) then they should be with the message when you hit Submit Reply. If you don't know how to resize them let me know I'll give you a my email address so you can send them and I will resize them and post them for you.
Ed
Old 11-15-2004, 06:33 PM   #7
old rebel
New Member
OK, I'm trying again.
box-joint-jig-shopnotes-magazine-front.jpg  box-joint-jig-shopnotes-magazine-backside.jpg
Old 11-15-2004, 06:43 PM   #8
old rebel
New Member
Here's a link to what it looks like when built to spec. http://store.yahoo.com/plansnow/boxjoint.html
Thanks again
Old 11-15-2004, 07:02 PM   #9
reible
Supreme Forum King
reible's Avatar
OK, now let me ask now you clamp the pieces to the jig? The only thing I can see that might be an issue is that the wood being cut will have to be clamped to be held in place you can not use the angle bracket to hold the wood in place. The bar stock you now have could be changed to wood or plastic the heavy metal should not be needed.
The jig I use on my table saw is not adjustable it is how ever very simple to make and you can make one for 1/4" and another for 3/8" and if you want one for 7/16". If you want detail let me know I will do a step by step for you (in a few days).
Ed
Old 11-15-2004, 08:46 PM   #10
old rebel
New Member
Ed
The stock to be cut is simply held by hand on the guide pin and fence. See the picture of this at http://store.yahoo.com/plansnow/boxjoint.html . The jigs I used before building this one were of the "fixed" pin type probably similar to the ones you describe. I still use them if I want a different size box joint, but this one looked really neat with all it's fancy micro adjustments and I thought it might be more versatile. Mostly I use the 1/4" box joint for about every thing i need to do.
Thanks again
Bj's box joint jig steveo Jigs and Fixtures 1 02-12-2008 07:49 PM
Incra half blind joint S Bolton Jigs and Fixtures 7 10-23-2007 01:38 PM
Hidden Mitre Joint DougO Router Bits - Types and Usage 9 10-20-2007 11:42 PM
My first finger joint box simplenik Table-mounted Routing 6 06-24-2007 08:52 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
