| | #1 |
| Registered User New Member | Does anyone know of a fixture that I can use for cutting multiple dado's the same distance apart? For example I would like to use a 1/4" bit and space the dado's 1-1/2" apart. I was thinking of something that would mount to the bottom of my router and slide into the previous dado. Any suggestions would be appreciated. Thanks. |
| | #2 |
| Forum Moderator Supreme Forum King | If you have a router table, you might could use the Oak-Park box joint jig if your stock is not extremely long. If that don't work, you could get a router guide for your model and most likey get 'er done that way as well.
__________________ Cheers, Bob |
| | #3 |
| Official Greeter Supreme Forum King Join Date: Sep 2004 Location: New Lebanon, Ohio "USA" First Name: Dave or "Doc" Posts: 4,709 ![]() | Welcome to the RouterForums kboughton. Could I ask what kind of router you plan to use?
__________________ Dave the "Doctor" In woodworking there is no scrap, only firewood. ![]() Please edit your profile with a name and location so we can better assist you and make for a friendlier forum. |
| | #4 |
| Registered User Forum Geek | Hi. If your router has mounting for a guide fence, you can modify the fence portion so that you are using a 1/4" thick guide. After cutting the first dado, the 1/4" guide goes into that dado so it's in line for the next dado. Hope this helps.. Woodnut65 Last edited by Mike; 05-14-2007 at 10:11 PM. |
| | #5 | |
| Forum Contributer Supreme Forum King | Or you can make a quick jig, see 1st. snapshot below Or you can make one that will do it all see other snapshots below. Bj ![]() Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 05-14-2007 at 11:49 PM. | |
| | #6 |
| Registered User Forum Fanatic | Hi "K", If you have access to the woodworking channel, check out when the Router Workshop is airing their episode on trivets. Rick has a simple jig (aren't they all?) to cut repetitive dados using a block and a plate. Check it out and it just may be the answer you are looking for. Joez
__________________ JoeZ If you never made a mistake, you never tried anything
| | #7 |
| Registered User New Member | Thanks for all of the ideas. I will definately be on this site often; you guys are a wealth of knowledge. Kevin |
| Framing a small piece of wood | lea6141 | Table-mounted Routing | 9 | 01-26-2008 10:29 PM |
| Wood for Cutting Boards? | buckshot | Lobby | 5 | 10-05-2007 10:45 AM |
| Cross Cutting Dado's On The Router Table... | challagan | Table-mounted Routing | 12 | 07-12-2007 09:56 PM |
| Cutting dados on a router table | paulcomi | Table-mounted Routing | 6 | 08-05-2006 11:52 PM |
| Issues Cutting Dovetail Dados with Table Router | Gazzalodi | Table-mounted Routing | 21 | 05-02-2006 11:40 PM |
