This is my exact width dado jig. It is similar to others that can be found on the internet. I built it after watching The Wood Whisperer's video a couple of years ago.
Today, I had to repair it due to a router run away,
plus it wouldn't fit the side of the baby changing station I am building.
I made it wide enough to fit a workpiece up to 24 1/2 inches wide. You can make it whatever width works for you, but that part of the jig is fixed.
The only hardware needed is a pair of 1/4 x 20 Star knobs and a pair of toilet bowl flange bolts. Note: Countersink the head of the bolts on the underside of the guides.
The way this jig works is you loosen the knobs, insert your workpiece and snug the adjustable side against it, and then tighten the knobs. That's all there is to it.
Use a pattern bit in your router. Run it down one side and then back up the other side. This eliminates the hassle of cutting dadoes for undersized 3/4 inch plywood. :dance3:
However, using a pattern bit, the smallest dado you can cut would be 1/2 inch. However, you could use a template bushing for a smaller size dado and adjust the jig to the width of the bushing. The jig would then become a straight edge guide.
The left side board is fixed in place with wood screws. My old version was glued and screwed. I had to beat it apart with a hammer so I could reuse the guides.
I cut new pieces of MDF 29 inches long so a kitchen cabinet member would fit (typical is 23 1/4 inches wide for base cabinets and 11 1/4 for the uppers).
I made the slots on the router table with a 1/4 inch straight bit (see pics). I made several passes cutting a little deeper each time until the bit broke through on the last pass.
This evening, I drew up the jig in Sketchup, so feel free to grab the pics and build your own.
This is my gift to y'all. Hope you build one. I bet you will like it.
Merry Christmas to one and all.
