Rate This Thread - Safety Pin Schmafety Pin.
Thread Tools Display Modes
Old 08-25-2007, 03:48 AM   #1
RustyW
Forum Geek
RustyW's Avatar
RustyW is on a distinguished road
Default Safety Pin Schmafety Pin
Awhile back there was a thread about safety, or starter pins. I told the story of the time one popped out while routing. So I started thinking of a better way. And the recent "sawdust saturday"thread that turned to a discussion on freehand table routing caused me to finally act on this idea thats been popping around between my ears.
I have 2 router table plates from 2 different sources. They are identical, and are both copies of the Rousseau plate. They have several holes for pins in the plate, and in the large removable ring. I think this project could be adapted to almost any plate. Also I have a lot of scrap beechwood that I have found to be a very close grained and hard wood, good for jigs. And lots of scraps of plastics since I work at a glass shop.
Well enough rambling,put the safety pin away and build one of these. It may save your fingers when needing to freehand a small project.
safety-pin-schmafety-pin-starterpin3.jpg  safety-pin-schmafety-pin-starterpin1.jpg  safety-pin-schmafety-pin-starterpin2.jpg
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline   Top - Reply with Quote
Old 08-25-2007, 06:01 AM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Rusty, a very nice guard design, but it will not work on the project you mentioned: the Magic Box. Once the box is assembled you round over the corners, and the guard would not allow for this. It is however a perfect way to attach above the table dust collection. Safety pins are still the answer. I like to use season 4 of the Router Workshop for examples since this DVD has been out the longest. When routing the profile on the window mullions you need to be able to get into 90º corners. This is only possible with a safety pin installed.
Bob Rosendahl will tell you that a safety pin should be installed between you and the bit. As you know from the mounting plates you own the holes for locating the safety pins are to the right of the bit, both for the long and the short sides. With disagreement between manufacturers on the best way to use safety pins it is not surprising to find it here on the forums.
Mike is online now   Top - Reply with Quote
Old 08-25-2007, 08:39 AM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI Rusty
I like it nice job....like you I'm not crazy about the pin you push in or screw in place for a starter pin or some times called safety pin...
I have said this b/4 but we think alot alike
see link(s) below
http://www.routerforums.com/attachme...pshots-rt8.jpg
http://www.routerforums.com/show-n-t...snapshots.html
Workshop Projects
Router Tables plans FREE, plus more
http://www.absolutelyfreeplans.com/W...p_projects.htm
RW Router Tip Archive
www.routerworkshop.com/router_tip_glossary.html
Floating Mortise & Tenon: A strong and Silent Joint
bobj3 is online now   Top - Reply with Quote
Old 08-25-2007, 09:07 AM   #4
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Both Rusty and Bj. have produced works of art which for certain operations would provide a very safe working environment but they would, as Mike says, get in the way for other types of projects.
Harry
harrysin is online now   Top - Reply with Quote
Old 08-25-2007, 09:50 AM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry and thanks
I should take a new snaphsot of the updated jig, it has been reworked so it can be used for all types of jobs ...I remove part of the plastic guard so the stock could slip by and ride on the bearing like when you want to use it for rounding over the edge on a box..it was a easy update and helps alot..
but it's still the safe way to get the job done..plus it lets me keep the table top clean of chips...almost all of them...almost all..
Bj
Workshop Projects
Old 08-25-2007, 11:20 AM   #6
Doyle
Forum Fanatic
Doyle is on a distinguished road
Thanks for the post Rusty.
I love your safety jigs - I keep a file of the posted jigs and things. I call it: the things to do file. I print them and take them out to the shop.
I have a question: I have noticed that some of the equipment shown in the posts are covered with plastic, how do you keep things from rusting?
Take care
Doyle
Our tools and machines never take prisoners!
Doyle is offline   Top - Reply with Quote
Old 08-25-2007, 11:24 AM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
I did go and take some snapshots of the updated jig..
The 2nd. line of snapshots, is the new Updated ver.with Vac. pickup to the center of the jig.
The Oak-Park white poly. pickup part I got from Bob N. ,thanks Bob, I did put it to work, but not in the way Oak-Park wanted me to...
This part comes with the Vac. system for the Oak-Park base plate, I don't know if they sale just this one part or not but it sure came in handy for what I needed it for...just the right size..
see below..
Bj
safety-pin-schmafety-pin-7273.jpg  safety-pin-schmafety-pin-7274.jpg  safety-pin-schmafety-pin-7274.jpg  safety-pin-schmafety-pin-7275.jpg  safety-pin-schmafety-pin-7276.jpg
safety-pin-schmafety-pin-7277.jpg  safety-pin-schmafety-pin-7278.jpg  safety-pin-schmafety-pin-7279.jpg  safety-pin-schmafety-pin-7280.jpg  safety-pin-schmafety-pin-7281.jpg
Workshop Projects
Is workshop safety needed? Check twice! Shop Safety 18 07-12-2008 10:27 PM
question safety pin warped Table-mounted Routing 2 02-22-2006 06:33 AM
What price do you put on safety? kp91 General Routing 13 01-08-2006 08:15 PM
Bit Safety Gourock Shop Safety 8 09-12-2004 08:32 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
