| | #1 |
| Forum Contributer Supreme Forum King | If you have a K2000 and you want to update to the K3 type then this one is for you... ![]() The new K3 has many neat items on it and I wanted to have the same on my K2000 so I did a bit of rework and now it's almost a K3 type... I did do a bit more on the update with slide blocks ,this will let me preset for the stock I use all the time from 1" wide to 6" wide....just lock the blocks and I'm set to make as many I need the same way...great for making face frames, you will also see a step block used to lift the drill bit and set it back just a bit to let me use the jig on 1/4" deep (sommerfeld way) T & G joints on the face frames.... If you have any question please just ask ![]() K3 system http://www.amazon.com/Kreg-K3MS-Mast...9747733&sr=1-1 ===========
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-02-2008 at 09:24 AM. |
| | #2 |
| Retired Moderator Supreme Forum King | Well, you had to know I would see this That's cool BJ. I will add this to my favorites and hopefully I can get around to doing at least the DC chute. Nice one BJ and thanks for all the photos as usual! Corey
| | #3 |
| Senior Moderator Supreme Forum King | Well thought out BJ. The dust collection is the biggest part of the upgrade and well worth doing. I like it.
__________________ Mike |
| | #4 | |
| Forum Contributer Supreme Forum King | Hi Corey Yep I thought you would see this one ,,You'er welcome, that's a real draw back about the K2000, is the mess it makes but now you and I and others can have a clean work shop with just a little vac.port, it's a bit tricky to make the press fit vac port but with the plastic snap on the top it will stay in place and do the a good job sucking up the chips... I just hate to blow out the chips after I drill one or two holes but now it's clean and ready for the next board... The Mfg. (Kreg) must have got many users asking for one and they put it on the K3 model and it's big sellling point I'm sure... I don't recall seeing any other of the pocket holes jigs have one yet..Note the pull up stop blocks on the new K3 model and it's a great item also but the slide blocks do the same thing but just a bit better... many times I will do some 3" wide or wider stock and the stops just don't do the trick..it was always just a guess where to put the stock for drilling but now the guess work is gone.Note::they dropped the support blue blocks on the side of the K3 jig model and that's a neat item to have for the pocket hole jig, they supports the longer boards , not to sure why they dropped them but you can add them to the K3 model easy...the longer the better ![]() ============= ================== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 09-14-2007 at 12:09 PM. | |
| Kreg system opinions? | Birch | Tools and Woodworking | 14 | 04-06-2008 04:52 PM |
| Kreg K2000PP ProPack Pocket Hole Jig $91 at Amazon.com | evolve | The Bargain Bin | 1 | 08-20-2006 02:59 PM |
| kreg joints | reible | Tools and Woodworking | 12 | 04-11-2006 09:36 AM |
| Toggle Clamps (Update) | Pop_pop1 | Table-mounted Routing | 1 | 08-29-2005 07:52 AM |
| Cisco 1841 Router & Windows Update Error | Hel27n | Lobby | 8 | 03-05-2005 07:22 PM |
