| | #11 | |
| Forum Contributer Supreme Forum King | Hi JDługosz "How do you get stops to work with the base diagonal like that?" See the YELLOW stop blocks in the drawing they can be used any where you need them.. ![]() ============== Quote:
| | #12 |
| Registered User Member | if you are in doubt of it being centered in leg stock cut tenon little oversized and sneak up on mortise I use a similar mortise jig bobj3 is talking about and really like it no problems being off centered |
| | #13 | |
| Retired Moderator Supreme Forum King | Quote:
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ | |
| | #14 | |
| Registered User Sr. Member | Quote:
The centering bearings and plate work well with long stock but what about when you are doing the end of a rail in a rail/ stile setup? Is it usable then or does it take a big setup to keep the router perched atop? I like the idea of a loose tenon because it seems is much easier to get perfect. Except when cutting the rail end, where it "seems" a tenon would be easier to create. I am currently working on a rail and stile cabinet door for glass with a profiled edge. My first attempt was TERRIBLE, but was to be expected. Do you recommend the tenon or loose tenon for this setup and how would I go about the mortise in the end of the rail? | |
| | #15 | |
| Forum Contributer Supreme Forum King | Hi petersenj20 I don't Recommend tenon or loose tenon for glass panel doors, because 1/2 of the joint is taken away by the glass..the norm. I do Recommend R & S type doors,, you may want to get the video from sommerfeld tools, it's the best one(s) I have come across...they will show you from sq. one how to make glass panel door that will stand up to the opening and closing they all get... he has may tricks that he will show you to make them come out just right the 1st. you make them...http://www.sommerfeldtools.com/list.asp?d=118&p=1 ============== Quote:
| | #16 |
| Registered User Sr. Member | That glass pane bit set is more than all my current router tools combined. You got to pay to play I know. While it may not be as strong as the glass panel bit (It is a broken joint of the type I am repairing so nothing is forever especially with 2 kids) it will work and at the same time hone my budding routing skills. I found another way to do it with an open floating tenon joint that looks pretty simple with no intricate jigs or expensive bits. This is what I will try next time. As always I appreciate yours and everyones input. This brings up a question. I have looked at a lot of doors and all are standard. When you have doors that open horizontally wouldn't it make sense to have the rails run the full width instead ending between the stiles? Why wouldn't this be better? (Been meaning to ask for a while.) |
| | #17 | |
| Registered User Forum Geek | Quote:
You have already gotten some very good technical answers to your questions.I just wanted to send some MAJOR KUDOS for your reasoning. Fancy/expensive gadgets may (or may not) make a job easier or faster or reduce the learning curve. But they are almost never as essential as the people who market them want you to believe. Otherwise no one would have been able to do the job before the gadget was invented. I APPLAUD your desire to develop your skills first - then your tool collection. That is what craftsmanship is all about.
__________________ The one who says it can't be done -- Should avoid interrupting the person doing it. | |
| | #18 | |
| Forum Contributer Supreme Forum King | Hi petersenj20 I knew I should have said you don't need to use his bits ,you can use just about any matched set, you can get them for $25.oo or lower. The key to get a strong joint is where the hinge will be placed, the hinge and the joint must hold the load of the full door,it comes down to how much glue you can get in the joint or to say the joint area..and the right angle of the joint comes into play also. Many cabinet doors are made with a shaper that's because the cutters on shaper cut 1/2" deep unlike most router bits only go 3/8" to 7/16" deep the norm...the deeper the slot the stronger the joint. http://cgi.ebay.com/2-pc-1-4-SH-Ogee...QQcmdZViewItem http://cgi.ebay.com/2pc-1-2-SH-Doubl...QQcmdZViewItem http://stores.ebay.com/Super-Carbide-Tools Just a note about Glass type cabinet doors,,, Once you have the door parts glued up use the rabbit bit to remove the inside lip for the glass,,,then sq. the corners out with a chisel or a corner tool like the one below... =============== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 10-17-2007 at 11:04 AM. | |
| | #19 | |
I'm sure there are a variety of answers. If it's another slow day -- I think I'll research it. On the practical side - I avoid that question altogether. I usually join rails and stiles with either lap joints or full tenons. That way both the rail and the stile go the full width/length of the door and you get maximum gluing surface. I saw this on some antique cabinets once and it made sense. Plus I liked that it was something I could do without any specialized tools - just a router or a saw. I cut any grooves or rabbets I needed for the panels as well as any shaping I wanted to do on the front before making the joint. Or - I added it as molding afterward. BJ - Thanks for the link to the less expensive sets. I have been thinking about buying some -- and at that price I can almost justify it.
| | #20 |
| Forum Contributer Supreme Forum King | Hi Cowboy You'er Welcome ![]() I have both types the CMT and the eBay ones, they both work very well and do a great job, the eBay ones are a bit harder to setup and use BUT they work ,,,and for the price they are hard to beat...and as you know you can drop tons of money into router bits and this is jiust one way around that... I just got a email from Price Cutters and they also have them on sale but not a low as the eBay ones. ![]() Talking about the eBay ones, I just order a new set and I forgot I had one in my shop ,duh, the set was a dovetail bit set ...the price was so good I jumped on it again...that's what old guys do they forget things now and then.. but you can't have to many router bits LOL it was only 54.oo bucks for a full set..of 16 pcs. I think they call that a CRS error.. ![]() =========
| Mortise & tenon vs. biscuits | berry | Starting Off | 4 | 07-25-2006 04:15 PM |
| Mortise & Tenon Jig | electrovoltz | Jigs and Fixtures | 6 | 04-20-2006 02:28 PM |
| Mortise & Tenon System Router questions | kenadian | Table-mounted Routing | 2 | 11-17-2005 04:22 PM |
| mortise and tenon system | kellyp | Jigs and Fixtures | 1 | 02-15-2005 04:36 PM |
| Mortise and Tenon Joints | TheVogon | Table-mounted Routing | 3 | 09-28-2004 11:15 PM |
