Thread Tools Display Modes
Old 10-04-2007, 05:10 AM   #1
garryjc
Jr. Member
garryjc is on a distinguished road
Default Push Stick Handle
I have two of the Oak Park push stick handles. I used a CMT 14 degree half inch dovetail bit to make a shoe for the handle. The bit was set for 3/8 depth of cut. The handle would not fit and could not be pushed into the dovetail cut.
I measured the shoe and it shold have fitted. CMT is a good brand, and the cutter seems to be 1/2.
What have I done wrong?
Any advice would be appreciated.
Garry
garryjc is offline   Top - Reply with Quote
Old 10-04-2007, 07:12 AM   #2
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi Gary: You might try adjusting the height of the bit to make it looser. I have the same handle from Oak-Park and a number of 1/2" 14 degree bits and have had no problem. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 10-04-2007, 07:43 AM   #3
garryjc
Jr. Member
How would the height of the bit effect the fit?
Assuming that the height does not bite into the handle and does grab the wedge of the shoe, how does the height affect the fit? If the bit is lower then the wooden shoe will fit lower on the handle, but the tightness of the joint should not change.
Or have I got this all wrong?
Garry
Old 10-04-2007, 09:21 AM   #4
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Garry, there is a saying for dovetail bits, heighten to tighten and lower to loosen!
Harry
harrysin is offline   Top - Reply with Quote
Old 10-04-2007, 09:38 AM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Gary
Why= the bit is cut on a 14 deg. angle, when the female part was cut it was set at 3/8" deep, and when you cut the male part it must be made a bit smaller so it just slides in easy...the base of the bit is 3/8" wide the norm on a standard 1/2" dovetail bit..and it's hard to get parts to fit when both parts are the same size. one needs to be a bit smaller..the male the norm.
that's to say make it just a bit thiner by moving the fence in ,but just a bit.
But besure to set the height right at 3/8" high...use your brass bars to do that.
Garry
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
I want Ricks push stick!! Birchwood General Routing 23 05-10-2008 12:47 AM
Rounding off the ends of a stick tpyke Table-mounted Routing 5 03-03-2008 05:14 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 02:08 PM
Push stick handles S Bolton Jigs and Fixtures 3 11-26-2007 07:20 PM
Modified Bj's push block Bob Jigs and Fixtures 5 06-03-2007 10:13 PM
