Thread Tools Display Modes
Old 10-08-2007, 01:26 AM   #1
FES
New Member
FES is on a distinguished road
Default Multiple Hinge Mortise Jig
Instead of making an individual hinge mortise template, I want to make a template out of 5/8" MDF that will have (3) spaces cut out, I can clamp to the edge of an interior door and mortise all 3 areas for the hinges in (1) setup. The doors are 1-3/8" thick x 32" wide x 80" long and I have (21 doors) to fix 3 1/2" round-corner butt hinges on. I am thinking about cutting a strip of 5/8" MDF 6" wide x 81" long, glue a tab approximately 1" wide x 4" long to each end of the strip. The tabs will have a mounting hole to pin the template to the door top and bottom with a drywall screw. Four (4) 1" x 2" x 10" fence strips, on approximately 10" centers, will be fastened to the template for clamping to door . Please advise if you think this template will work or maybe someone will have a better idea ? Your advice will be greatly appreaciated. Regards, Fred
FES is offline   Top - Reply with Quote
Old 10-10-2007, 07:19 PM   #2
FES
New Member
Would someone advise me on this ? I am totally a novice when it comes to doing anything with a router. Thank you.
Old 10-10-2007, 08:44 PM   #3
AxlMyk
Supreme Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
You might consider using plywood. It would be much stronger. Seeing as how MDF is similar to cardboard, you might get your fence strips breaking off.
Otherwise, it sounds like a good plan to me.
AxlMyk is offline   Top - Reply with Quote
Old 10-10-2007, 09:10 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi FES
Because you have 21 doors to do you may want to buy or just rent a hinge template jig set up,,, you can always sell it after you get done with it,,
But so many doors are not all the same size it can be off by 1" and the will make your home jig so much fire wood...
Porter-Cable 59381 Hinge Butt Template Kit
http://www.amazon.com/Porter-Cable-5.../dp/B0000224KV
Carey 300-2 3 Hinge System
http://www.tools-plus.com/carey-300-2.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-10-2007, 10:05 PM   #5
FES
New Member
Thank you much getting back to me and for the information. Doubt if I can afford to buy a mortise jig. Understand they are quite expensive. Have to check around and see if I can rent one. Good point taken about the doors not being identical in dimensions. Thank you. Best Regards, Fred
Old 10-11-2007, 07:09 AM   #6
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi Fred: I have had recent need of a similar mortice jig for some doors in a house.
I bought a jig from Home Depot made by Porter Cable, it cost about 25 USD.
It hadles 3 1/2, 41/2,hinges with 5/8ths radius 1/4" radius and with a chisel they can be squared up from 1/4". The bit that comes with the jig is HSS. and is practically useless. I replaced it with a bit that PC recomends, for another 20 USD.
I did about 10 doors with it and it was certainly worth the investment.
Hope this helps. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 10-13-2007, 08:03 PM   #7
FES
New Member
Thanks Woodnut65 for the information. I thought the jig would cost a whole lot more. I will check with HD. I guess, for 25 USD, it is a single hinge mortise jig but worth looking at anyway. I agree about the HSS bit. Bought a carbide edge 1/2" and 3/4" bit today. Don't know for sure which diameter will work best but going to try the 3/4" since it will remove more material quicker. Regards. Fred
Old 11-10-2007, 09:07 AM   #8
FES
New Member
Update: I made my multiple hinge mortise jig for both, right and left hand hinges, using 1/2 " MDF, glued and screwed 1/4" plywood at the hinge locations big enough to allow the 1/8" offset for the 3/4" bushing and used a 1/2" mortise carbide bit. Also, I glued and screwed a strip of 1/4" x 1" about 1" from each edge of the hinge location. This strip was used to screw the jig onto the door edge with 1" drywood screw which held it in place. I attached 1" x 2" x 12" strips with glue and screws to the underside which served as a stop that rested against the side of the door giving the required depth of the mortise. Happy to say, the jig worked and all 21 doors are up and hanging. It took 2 1/2 hours to mortise all the doors. I will post a photo of the jig that might give others ideas, if I can figure out how to do that. Thank you all for your help on this one.
Old 11-10-2007, 11:42 AM   #9
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
A picture would be a lot easier to see...
Joe Lyddon is offline   Top - Reply with Quote
Old 11-12-2007, 01:29 PM   #10
FES
New Member
Will do, Once I figure out how to post a picture.
Rounded Mortise & Squared Tenons? Nickbee Table-mounted Routing 15 01-16-2008 09:11 PM
My mortise jig guyos Jigs and Fixtures 3 10-04-2007 11:07 PM
Rolling Mortise Jig - the test simplenik Table-mounted Routing 9 07-23-2007 11:54 AM
Slotted Hinge Installing challagan Tools and Woodworking 17 01-20-2007 07:55 PM
mortise and tenon grb101 Table-mounted Routing 11 12-31-2004 09:16 PM
