| | #1 |
| Registered User Forum Geek | I did my first Incra half blind dovetail joint this evening. I noticed that the joint fits snugly, but that there are several gaps in the places I have noted on the joint. Can anyone tell me what I may be doing wrong. Whitesid 1/2 14 degree cutter. Thanks Steve Bolton |
| | #2 |
| Registered User Forum Geek | I forgot the photo. Sorry. sb |
| | #3 |
| Retired Moderator Supreme Forum King | It looks pretty good Steve I haven't had a chance to use mine yet. My guess would be just moving or shifting during the cut, maybe debris between the fence and the right angle fixture etc. You using any kind of DC on your set up? Also is your stock absolutely flat without any cup or bow in it? Doesn't take much to make it just a tad off. Still, it looks good. Corey
| | #4 |
| Forum Contributer Supreme Forum King | HI SB Looks good, you need some room for the glue,, I think the word you are looking for is Practice ,,, plus keep the stock from moving around...and hold it to the fence...it comes in time... but good job ![]() ========
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 10-22-2007 at 11:46 PM. |
| | #5 |
| Registered User Forum Geek | Cory: What do you mean using "using any kind of DC on your set up"? thanks sb |
| | #6 |
| Retired Moderator Supreme Forum King | Steve, I meant dust control.. shop vac etc. Just putting a wand back in there back behind the fence will help. Just a little dust and chip build up will move you off the fence. The bit can also try to pull the stock and move it a bit. I will be sure to use a push pad as shown in the video to keep it on the fence and down when cutting the slots. Corey
| | #7 |
| Forum Contributer Supreme Forum King | Hi SB Here's a link to some Vac.pickups you make easy for your Incra setup plus a Mod.of the push block that helps hold the stock true...and tight to the fence all you need to do clamp it to the push block and let the extra guide do the work for you.. The Mod. is a easy one to make BUT it must be made dead on... ![]() http://www.routerforums.com/47957-post39.html http://www.routerforums.com/53713-post1.html http://www.routerforums.com/jigs-fix...estion-bj.html
| | #8 |
| Registered User Supreme Forum King | It looks like where the stock was held down tight, it produced a loose joint. You'll notice the second from left is tight and the rest are loose. Make sure you hold the stock down tight, and lower the bit an eyebrow hair.
__________________ Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ |
| Half Blind Router Template Question | stevek433 | Introductions | 4 | 03-01-2008 12:17 PM |
| Incra Ultra How-To (Box Joints + Other Stuff) | Nickbee | Show N' Tell | 5 | 01-21-2008 09:14 AM |
| 2nd Incra joint | S Bolton | Jigs and Fixtures | 2 | 10-23-2007 11:14 PM |
| Unique half blind dovetail | S Bolton | Jigs and Fixtures | 13 | 09-03-2007 12:26 PM |
| Incra jig and rabbeted half blind dovetails | S Bolton | Jigs and Fixtures | 10 | 08-24-2007 02:06 PM |
