| | #11 |
| Registered User Jr. Member | Hi Bob, try Woodline USA at the below web page, it is for a tongue and groove cutter, $32.00. It may help or maybe not. http://www.woodline.com/scripts/prod...?idproduct=558 Good luck with your clock |
| | #12 |
| Registered User New Member | I use my table router to make tenons. 2 passes of infinite adjustment for size using either a 1/4 or 1/2 inch spiral or straight bit. I can even hold the piece upright and nip off the ends to make it a hidden tenon. For making the matching mortice I set the hight and distance using a fence. I place the mortice exactly by penciling a start and stop line accross the upside of the piece. I then focus my laser (cieling mounted) directly on the bit and it marks the top of the piece for start and stop. It is precise and exact. I also use the laser for making initials in pieces. It is a great device. |
| | #13 |
| Registered User Member | I've found that any kind of tennon on a router table is very dependant on the thickness of the stock and how straight it is. This applies not only to small tennons such as in a face frame but even more to tennons in carcase constructions that may be as long as a shelf is wide. For this I use a Woodrat instead of the table. The tennons are dead accurate and repeatable. Haunches are very easy to add (or leave wood behind for <grin>) and though I usually stick to about 1 inch long, 2 inches are an easy possibility. In the long shelf-end tennons, slight curvature to the board does not affect producing a straight tennon and not affected by board thickness. ...Doug |
| | #14 |
| Registered User Forum Fanatic | Here is a nice jig for making tenons with router. http://www.ukworkshop.co.uk/jigs/tenon/
__________________ The Geezer |
| | #15 |
| Registered User Jr. Member | I have not tried this, but here is a link to a tenoning jig for the router. It looks simple enough. http://www.dewalt.com/us/articles/article.asp?ID=244 ![]() |
| | #16 | |
| Registered User Forum King | Quote:
Tom | |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 08:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 06:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 02:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 12:02 PM |
| New Router my way | reible | General Routing | 14 | 06-10-2006 10:19 PM |
