Rate This Thread - Tennons on my router.
Thread Tools Display Modes
Old 01-13-2005, 06:17 PM   #1
Densa
Jr. Member
Densa is on a distinguished road
Default Tennons on my router
Does anyone have a set up that would help me make tennons on a router table? I'm building a clock case and need to make a number of small tennons in 1"x1" oak and it would be great if they were all the same. I'm being steered to a jig for my table saw but think I would have more control with my router.
Bob
Densa is offline   Top - Reply with Quote
Old 01-13-2005, 09:07 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Bob, once you have done the set up on your router table you should get consistant tenons. Just remember to use a backerboard to prevent tear out.
Old 01-14-2005, 05:28 PM   #3
JimH
New Member
JimH is on a distinguished road
I used my router to build a jig for my table saw to make either lap joints or tenons. If you use the same setting principles as you would for the router, you get a consistent tenon or lap joint every time.
JimH is offline   Top - Reply with Quote
Old 01-15-2005, 10:41 AM   #4
kp91
Forum King
kp91's Avatar
You can use a bottom cleaning bit (they make some pretty wide ones) for cutting tenons quickly (2 passes instead of 6) on each side. If you are going to be doing a lot of them, it might be something you would like to invest in. A sample is at the site below. Either a sled or a large backer block will keep your tenons square.
http://pricecutter.com/html/catalog/...tGroup.asp/487
1 John 1:9
Old 07-10-2005, 06:09 AM   #5
joekuhn
New Member
joekuhn is on a distinguished road
Question Tenoning Router Bit
On a couple of Router Workshop episodes, I have seen the Rosendahls use a router tenoning bit which simultaneously removes material at the top and bottom of a piece of stock leaving leaving a tenon. If I remember correctly, the bit was adjustable for different tenon widths. It seemed to me that this method was superior to using a tenoning jig on a table saw. Unfortunatley, I haven't been able to find a bit like this in any of my catalogs and it isn't offered by Oak Park. Does anyone out there know where such a bit can be obtained?
joekuhn is offline   Top - Reply with Quote
Old 07-10-2005, 08:49 AM   #6
Senior Moderator
Supreme Forum King
Rockler or Woodcraft both stock tenoning bits. Adjustable tenoning bits are made by Freud & Amana.
Old 07-11-2005, 05:17 AM   #7
template tom
Forum King
Bob
Have you considered 'Floating Tenons'?? where the router in the Plunge mode could be used
Tom
Old 07-16-2005, 08:49 AM   #8
joekuhn
New Member
Mike:
I have looked in my Rockler and WoodCraft catalogs. I have looked at the Freud and Amana websites. I can't find any tenoning bits, adjustable or otherwise, in any of these sources. Could you give me specifice page numbers or model numbers.
Thanks,
Joe
Old 07-16-2005, 03:58 PM   #9
Senior Moderator
Supreme Forum King
Joe, I viewed the Amana adjustable bit in an ad in The Woodworkers Journal. I believe the Freud bit was in Popular Woodworking, and I am pretty sure I saw it at the Performance line tool store in Warren, MI. http://www.performancelinetool.com/
These are relatively new bits.
Old 07-17-2005, 08:57 AM   #10
jerrymayfield
Forum Geek
Are you speaking of an adjustable rabbeting bit ?. By the way I live in Mi. also.
regards
jerry
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 08:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
New Router my way reible General Routing 14 06-10-2006 10:19 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
