Problem with porter cable dovetail jig - Router Forums
post #1 of 9 (permalink) Old 12-13-2007, 09:52 PM Thread Starter
Have been al urker for some time, looking for help, I just purchsed the PC 4212 dovetail jig. I'm having a problem with the parts not lining up. Have cut nice fitting dovetails but the front is about 3/32 out of alignement. The edge of the side is a little lower, than the edge of the front. Anyone have this problem? and did you get it corrected?
ldsmith1234 is offline
post #2 of 9 (permalink) Old 12-14-2007, 12:18 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the forums Ldsmith. Glad to have you join us.
Dave
the "Doctor"
Dr.Zook is offline
post #3 of 9 (permalink) Old 12-14-2007, 12:54 AM
Community Founder
Mark's Avatar
First Name: Mark
Welcome to the community!
Mark,
Founder of RouterForums.com
Mark is offline
post #4 of 9 (permalink) Old 02-12-2008, 06:23 PM
Same problem
New to the forum. I just got this jig and though it works well I have the same problem with the pieces not lining up correctly when put together. I don't see any replies here, any help or ideas?
Marcus522 is offline
post #5 of 9 (permalink) Old 02-12-2008, 06:51 PM
Dr.Zook's Avatar
Welcome to the forums Marcus. Sorry I can't answer your question, I don't have a dovetail jig.
Dave
the "Doctor"
Dr.Zook is offline
post #6 of 9 (permalink) Old 10-20-2012, 04:21 PM
First Name: Hank
Solution to alignment problem
I had the same problem. The problem lies in the alignment stop on the left hand side of the jig. This sets the offset between the horizontal board and the vertical board. For the large jig, this is 1/2 inch. The problem is the manual says position the vertical board centered between the pins of the jig and then slide and lock the alignment jig against the vertical board, and you will have a stop for the horizontal board with the correct offset. The problem is the alignment stop doesn't lie perpendicular to the jig when you press it firmly against the jig. So this throws off the alignment between the top and bottom boards. The way I got around this is to position the vertical board between the pins and square it up using the dovetail template. Then remove the template and position the horizontal board perpendicular to the vertical one, and offset it 1/2 inch to the left. Lock these boards in place with the jig clamps. Then slide the offset stop against both boards and tighten the lock screw. You won't be square with the offset stop, but you only need to touch the boards in two points, one for the vertical board and one for the horizontal.
I don't know why they don't do a better job with this part.
Once you get this working, the next item is depth of cut. 1/64 can make the difference between a tight fit and a loose fit. After this is dialed in, then adjust the template position if needed forward or backward. If the depth is not right, you'll never get it dialed in.
Pain in the butt to learn to use. I must have made 50 joints before it made sense.
Sorry this is a few years after, but just bought mine and was searching for solutions myself.
hgrant0617 is offline
post #7 of 9 (permalink) Old 10-20-2012, 07:37 PM
First Name: Duane
Don't have one but I understand there is some good info here...
Dmeadows is offline
post #8 of 9 (permalink) Old 10-22-2012, 09:01 AM
First Name: Hank
Good reference
This is a good additional manual. One of the best items is the simple addition of a set screw to lock in the template locator. This uses 16 threads per inch. Next time, hey should use something finer. One revolution is a 1/16 th when you are trying to work at 1/64 th. Just buy a 3/8-16 nut at lowe's. This is an essential addition for reproducibility.
post #9 of 9 (permalink) Old 11-03-2013, 12:09 PM
Solution to Allignment Problem
Thanks for above which is very useful.
Can you clarrify what you mean say "dialed in" with respect to depth of cut?
kkclimber is offline
Human Verification
Porter Cable 4212 dovetail jig dwwilson44 Jigs and Fixtures 2 01-28-2013 10:43 AM
Porter Cable 4112 Dovetail Jig vapochilled Jigs and Fixtures 16 01-03-2012 07:19 PM
Porter Cable Motor Stuck LarryP Introductions 4 10-16-2006 04:03 PM
POrter Cable dovetail jig 5005 aztd Jigs and Fixtures 3 08-08-2006 01:07 AM
Anyone use the Porter Cable 7216 Omnijig ??? emailtim Jigs and Fixtures 8 03-28-2006 09:37 AM
