Thread Tools Display Modes
Old 12-23-2007, 08:18 AM   #1
tpyke
Sr. Member
tpyke is on a distinguished road
Question Oak Park Beveled Jointer Jig
I bought a few E-plans from Oak Park. They are all pretty simple and straight forward to understand. I am only having one problem, with the heart waste basket plan...I don't know if they omitted something in the plan or if I missed something (even though I re-read the plan twice looking for this...), but they say: "Follow plans to make a bevel jointer fence". They don't give you plans to make the jointer though. They show you this picture, where you can see that the outfeed is not the same width as the in feed, but there are no measures:
Can anyone give me a bit more insight on building a jig like this?
tpyke is offline   Top - Reply with Quote
Old 12-23-2007, 09:44 AM   #2
Hamlin
Supreme Forum King
First Name: Ken
Typically, I think you'd want the "fence" to have an over-hang on your table top so as to clamp it down easily.
The offset of the jointer can be whatever you are looking for. Not sure that there is a "set" deminsion for this. I believe the norm is 1/16" - 1/8".
I'm sure there are others here with a greater wisdom than I that will chime in.
Ken
"A VETERAN"
Old 12-23-2007, 09:55 AM   #3
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
If you are trying to used the fence to join boards then the out feed should always be wider then the in feed about 1/32 or 1/16 at most, it looks like it’s reversed in the picture.
If you are trying to do bevel cuts at 22.5 then both in and out feed should be same width. But, The angle board in the picture does not have enough support for a safe angle routing operation. Much safer and easier to use an angle router bit.
Most plans are meant to give you some idea but are not necessarily accurate. Always use precaution.
Router is still my name is offline   Top - Reply with Quote
Old 12-23-2007, 10:15 AM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi tpyke
Many and most of Bob's R. jigs are neat but sometimes it's best think out side of the box..
If you have a jointer this is a easy job but if not then like Router pointed out just use the right bit for this job..
Like the one below
http://www.sommerfeldtools.com/item....02004&d=80&b=2
Just a note*** you don't need to use both bits, one will do the job,the glue up will hide the joint,that's to say just use the male bit..it's a quick way to put on the 22.5 deg.on the stock and it's a safe way...
Just one bit you can use and it's a bit cheaper..and easyer to setup and use.
Multi-Sided Glue Joint Router Bits
http://www.mlcswoodworking.com/shops...ed_glue_anchor
This bit can can be used to put in corner brace brackets in cabinet work.
Just run the stock by the bit with the stock on end...it will put in a notch to set the corner brace in place...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 12-23-2007, 10:27 AM   #5
tpyke
Sr. Member
Actually, I was thinking about just cutting the bevel on the boards with my bandsaw, but the jig also serves to cut a slot down the length of the 22.5 degree bevel to join all the boards together like a biscuit jointer would. Do 22.5 degree angled slot bit exist?
Old 12-23-2007, 10:42 AM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi tpyke
Most biscuit jointers can be set at 22 1/2 deg..
But using the band saw to cut the stock on the 22 1/2 deg. will be tricky..try your table saw with a good blade.
Then once you have the stock cut at the 22 1/2 deg. move the fence over just a bit and put in a slot for a spline..
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 12-23-2007, 11:17 AM   #7
tpyke
Sr. Member
Sorry about that! I meant table saw.....
Good idea about moving the fence over!
Old 02-24-2008, 07:52 AM   #8
Hamlin
Supreme Forum King
First Name: Ken
In the DVD series 5, 501 shop step stool, Rick uses a similar fence. They use a 15degree bevel and the offset on the outfeed side of the fence is 1/8". A small note *** the bevel angle can be anything YOU want it to be.
Click to Enlarge
Ken
"A VETERAN"
Old 02-24-2008, 07:23 PM   #9
tpyke
Sr. Member
There we go! Now I can reproduce the jig exactly. Thanks for that Hamlin!
I'm surprised though....I thought that Bob or Rick would have chimed in with specs on the jig ,I thought they came on here once in awhile...
Old 02-24-2008, 08:47 PM   #10
Hamlin
Supreme Forum King
First Name: Ken
You're welcome.
One thing that I've learned from this "relaxing" hobby, for jigs, you can make them in any fashion in which that work for you.
As for Rick and Bob, I haven't seen them on in quite some time now.
Ken
"A VETERAN"
Mounting an Oak Park Box Jig on Non Oak Park Table challagan Project Plans and How To 53 09-17-2008 11:09 PM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 02:38 PM
Oak Park table old folks Table-mounted Routing 4 08-07-2007 12:08 PM
Another jointer question. ryan.s Tools and Woodworking 10 05-08-2005 12:00 PM
