| | #1 |
| Registered User Forum Geek | I need to plane some exotic wood blanks. Right now they are cut to 6” x 3” and about ½” in thickness. A few have a slight cup to them. I’d like to plane them all down to about 3/8” and at the same time remove the cup. Of course I don’t have a planer or jointer so I am devising a plan with the router. Thanks! |
| | #2 |
| Registered User Sr. Member | BUMP!! Someone's got to have figured some way to plane/joint with a router.... |
| | #3 |
| Registered User Forum Geek | I have a plan which involves "clamping" the work piece from 4 sides then using a dado clean out bit to plane the wood a little at a time from the top. I'm not sure if it will work without "down pressure" clamped on the piece. It would be great if it does as the whole piece would be able to be planed at once. I'll report more as I get started... |
| | #4 |
| Retired Moderator Supreme Forum King | Check out the posts by AxylMyke and Harrysin where they use the router skis to plane a board. Might be in the template guide section. Corey
| | #5 |
| Forum Contributer Supreme Forum King | Nick, take a look at this link to one of my projects, it shows the router mounted on skis and planing a curved piece of wood. Skis can be made very simple or as complex as you like. To hold the pieces simply pin four pieces of scrap tightly along each side. Plane the convex side first for stability. http://www.routerforums.com/49052-post1.html
__________________ Harry |
| | #6 |
| Registered User Forum Geek | Thanks Harry!!! That was my game plan to hold the piece from the 4 sides then route from the top. Thanks for confirming that my thought should work. I'll post some pics once I get my set up working. The 3" x 6" bloodwood I have has a similar "cup" as your piece did. I figure once I get the dimension of the wood down to 3/8" it should be worked out (it's currently 1/2" thick). Thanks for sharing! |
| Hand Plane | Benny LaBaw | Wood Scrolling | 7 | 06-28-2008 11:07 AM |
| WoodWorks Show in Richmond, VA | kp91 | Woodworking Shows & Events | 0 | 10-14-2007 01:36 PM |
| New woodworking show on PBS! | Toolfreak | Tools and Woodworking | 3 | 03-14-2007 06:57 PM |
| Woodworking show Dulles Expo Center | realsmiley | Tools and Woodworking | 1 | 02-19-2005 12:45 AM |
| Improving our favourite show | dustmaster | Lobby | 7 | 12-19-2004 07:40 PM |
