Thread Tools Display Modes
Old 01-08-2008, 09:24 AM   #1
Nickbee
Forum Geek
Nickbee's Avatar
Nickbee is on a distinguished road
Default Bosch Circle Jig, 1st Use…
When I got my 1617 EVS combo a few months ago it came with a “free” Bosch edge / circle guide:
Well I got commissioned to make another yarn swift which is based on a Lazy Susan. So I had a chance to break this out and put it to the test.
I secured the work piece from under an MDF platform with a few 1” screws. The bottom of the lazy Susan circles will be hidden so the small holes the screws made are a non issue.
The compass center gets taped down. Duct tape was the strongest thing I had around so it’s what I used. In the future I might try to match up a screw with the center peg and bore a hole in the center. But overall this method worked well.
I used a Whiteside ¼” up cut spiral bit. Using the turret on the plunge base I made passes at 1/8”
Almost there:
And I’m through!
The results were pretty good. Some sanding will be required but not really as much as last time when I used a jig saw. And both circles I cut were identical!
Nickbee is offline   Top - Reply with Quote
Old 01-08-2008, 06:42 PM   #2
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Looks damn good there Nick, nice job and your friend is sure keeping you busy on the yarn equipment!
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 08:54 AM
Which hole pattern should I get (plate for a Bosch 1617)? Nickbee Table-mounted Routing 1 11-23-2007 06:49 PM
Hitachi M12V and Bosch 1619EVS routers LBrandt Table-mounted Routing 3 06-03-2006 10:42 AM
Bosch 1617EVSPK or Bosch 1619EVS LBrandt Table-mounted Routing 18 05-19-2006 03:35 PM
My New Bosch Router Bosch 1617EVSPK Review GoonMan General Routing 2 04-02-2005 05:25 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
