| | #1 |
| Registered User New Member | I took a piece of 1/8" plexiglas and used my router (along with the router guide from rockler). The template turned out perfect. I cannot get a good clean cut however. My router edge get stuck on the corners of the oposite side of the "X". I often over-shoot the edges. Should I used thicker plexiglas? I though about using a larger router base, this would float over the entire template. I have been using double-stick tape to hold down my piece I am cutting. I drilled/counter sunk four holes on the template, to secure with screws. Any suggestions? |
| | #2 |
| Registered User Dedicated Member | Use a table-mounted router and flush trim bit with bearing? Brian
__________________ "Every day spent sailing is another day added to your life" |
| | #3 |
| Senior Moderator Supreme Forum King | Let me see if I understand what you are doing. You cut a template from some material and are using it with a guide bushing to cut out an "X" shape from 1/8" plexiglass? Or are you making an "X" shaped cut out in 1/8" plexiglass? More detailed info please.
__________________ Mike |
| | #4 |
| Registered User New Member | My template is plexiglas. The material I am cutting is 1/8 mdf (cabinet backer-board). About using the router on a table..... I cannot visualize this???? Do you have any links with examples? |
| | #5 |
| Senior Moderator Supreme Forum King | To my way of thinking the easiest way to do this job is with your router mounted in a router table. I would use a 1/4" straight bit with a bearing on the end. These bits are called flush trim bits and are commonly used for trimming Formica or veneer on cabinets. Fasten your template to your MDF, rough cut it to shape using a jig saw if possible. Adjust your bit height above the table so the bearing rides on the template with the MDF on the bottom. Slowly bring your template onto the bearing and then move it around in a counter clockwise direction. You will have excellent control, easily see where your cuts are and get a nice smooth finish.
| | #6 |
| Registered User New Member | My template is a 8" X 10" plexiglas rectangle. The "X" is cut out in the center of this. My "X" is about 5". If I understand what you are stating - make a template that is an "X", not a template with a "X" cutout of it - correct? |
| | #7 | |
Ed | |
| | #8 |
| Registered User New Member | Thanks for the help. I was wanting to prevent cutting another template - but now I am glad I did. I cut another "X" out of 1/4" plexiglas - double-stick taped it to the mdf. Used my fixed router on the router table with a 1/4" straight bit with a bearing on the end. Perfect cut everytime and I can now see what I am doing with much better control. Thanks for all the help. |
| | #9 |
| Senior Moderator Supreme Forum King | I'm glad my idea helped. When you finish your project post a photo for us to see.
| | #10 |
| Registered User New Member | I posted a picture of the final project. |
