Rate This Thread - Jig.
Thread Tools Display Modes
Old 02-01-2008, 08:22 AM   #1
bigh429
New Member
bigh429 is on a distinguished road
Default Jig
How can I make a jig to place holes? I'm making a golf ball rack. It has a piece in the middle that will have through holes. The two sides don’t have through holes. Each piece is approximately three feet long and I need the holes to be spaced two inches apart with one inch between the two side by side. I can get the two side by side on the drill press with a spacer but I haven’t figured out how to feed in two inch increments. Thanks Bigh,
bigh429 is offline   Top - Reply with Quote
Old 02-01-2008, 09:25 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi bigh429
Not to sure if this is what you want..
"how to feed in two inch increments"
Bj
Old 02-01-2008, 09:56 AM   #3
curiousgeorge
Supreme Forum King
curiousgeorge's Avatar
curiousgeorge is on a distinguished road
A simple jig that won't take longer to make than it would to drill the holes would be to mark a board with the desired increments. Drill the first hole with the jig attached to the fence, then align the first mark on the jig to the end of your board, making sure you don't move the board, and clamp the jig to the fence. Then slide the end of the board to the next mark and drill the next hole. Repeat as necessary.
George
If you can't fix it with a hammer, you've got an electrical problem...
curiousgeorge is offline   Top - Reply with Quote
Old 02-01-2008, 10:17 AM   #4
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
Never tried it with larger holes --
But for spacing holes for shelf pins --
I've had pretty good luck just using a strip of pegboard.
The one who says it can't be done --
Should avoid interrupting
the person doing it.
Drugstore Cowboy is offline   Top - Reply with Quote
Old 02-01-2008, 02:52 PM   #5
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Pegboard is the easiest way to layout equal spacing. Most brands have the holes on 1" centers so life is simple. This will let you position the golf ball holes with ease. Once you have drilled your holes in the ends of the center board you can use a couple of dowel centers which go in the holes to transfer their location to the side boards, if that is what you were asking about. Dowel centers come in different sizes to match common dowels and are only a couple dollars a package.
Old 02-01-2008, 08:20 PM   #6
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Each of those ideas will work fine, however I do think that Bj's is the way that I would go, it's so simple but will give perfect results every time even if a ten year old were left to do the job.
Harry
harrysin is offline   Top - Reply with Quote
Old 02-05-2008, 03:57 AM   #7
bigh429
New Member
Thanks, I'll give it a try!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
