Help
Katie Jig
This is a discussion on Katie Jig within the Jigs and Fixtures forums, part of the Routers category; Bob (and other Katie Jig users) I know you have a Katie jig and I ...
Old 02-02-2008, 10:29 PM   #1 (permalink)
S Bolton is on a distinguished road
Default Katie Jig
Report Post Report This Post!
I know you have a Katie jig and I bought the little Jr. one. I am wondering if the joints need to be adjusted like the Gikins (with spacers).
I haven't been able to use mine yet, but I was surprised when I measured the backing board and they appear to be a metric size. Not that this has anything to do with it, but then I wondered if you also have to use shims.
Steve Bolton
S Bolton is offline
Old 02-03-2008, 05:47 AM   #2 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi SB
I didn't get any spacers with the one I have...other than the big ones that are the same size as the fingers...
But you can move the fingers around and use the big spacers to setup a new pattern..
e.g. to put in 2 dovetails in a 6" wide board...
like below
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
bobj3 is online now
Old 02-03-2008, 09:45 AM   #3 (permalink)
Does anything govern the tightness of the joint? Do you have to use shims or is it automatic?
sb
S Bolton is offline
Old 02-03-2008, 11:30 AM   #4 (permalink)
bobj3's Avatar
Hi SB
The tightness of the Joint is govern but the finger templates and it's all automatic so to speak and all you need is set the height of the bit to the stock thickness...
The easy way for me is to put the stock in the jig and put the other part of the joint right next to it and draw line and then move the bit or down to the line,the line thickness will let the pin stick out just a bit when it's glued up..then sand or use a trim bit to clean up the joint..
sb
Part Finder
Bob J.
bobj3 is online now
Old 02-04-2008, 05:27 PM   #5 (permalink)
I think I was actually referring to the backer board when you refer to the spacers. I think we are talking about two different things. I mean the MDF backer not the spacers.
It seems like they must be a metric size which is irritating. Anyone know where to buy metric MDF?
Steve Bolton
S Bolton is offline
Old 02-04-2008, 06:32 PM   #6 (permalink)
bobj3's Avatar
Hi SB
It's no big deal ,,it's like a match once you use it up you just get one more, it can be anything you want to use..
Steve Bolton
Part Finder
Bob J.
bobj3 is online now
Old 08-03-2008, 09:54 PM   #7 (permalink)
Bob, would pine or aspen work as a backer board? Do you use your Katie on the router table?
sb
S Bolton is offline
Old 08-03-2008, 10:00 PM   #8 (permalink)
bobj3's Avatar
HI Steve
You bet if it's flat ,,, Yes I do you my Katie jig on the router table..
sb
Part Finder
Bob J.
bobj3 is online now
Old 08-03-2008, 10:10 PM   #9 (permalink)
Anything better that pine and aspen? The mdf I have isn't quite the right size.
Do you have to square the bottom fingers or anything or is it automatic?
sb
S Bolton is offline
Backer board for Katie of Gifkins S Bolton Tools and Woodworking 1 06-21-2008 11:21 PM
Katie Jr. Dovetail Jig S Bolton Table-mounted Routing 44 02-02-2008 03:30 PM
Katie Jig vs. Gifkins S Bolton Jigs and Fixtures 14 11-27-2007 09:34 PM
Katie Jig Richard Stopher Introductions 4 06-20-2007 10:35 PM
Anyone Use the Katie Jig? KenC Table-mounted Routing 3 03-27-2005 02:57 PM
