Thread Tools Display Modes
Old 09-18-2004, 02:24 PM   #11
sailer
Jr. Member
sailer's Avatar
sailer is on a distinguished road
While at a woodworking show a couple of yrs. ago, I saw a guy demonstrating router products that used golf balls for his clamp handles. He just drilled the holes, as with the dowels and epoxied them in place. I did it, and it works great. Its a whole lot easier on the hands than the dowels & broom handles.
sailer is offline   Top - Reply with Quote
Old 09-28-2004, 11:52 PM   #12
Papaboard
New Member
Papaboard is on a distinguished road
There does not appear to be a preponderance of evidence readily available to support the claim of golf balls exploding, so I am withdrawing my comments on the matter. Here is one link I found which refutes it:
http://www.straightdope.com/classics/a5_168.html
Previous post excerpt: "I wouldn't advise drilling into golf balls to use them as handles as they may explode... balls made today have a center core, liquid in many cases, which is under tremendous pressure which could explode the ball if it were punctured, much like an aerosol can."
I elected to use the finely ribbed handlebar grips which they have on some off-road bicycles instead.
Papaboard is offline   Top - Reply with Quote
Old 09-29-2004, 08:00 PM   #13
Haymaker
New Member
Haymaker is on a distinguished road
Go to Westlake Hardware. Purchase the foam that fits around air conditioning pipes, buy in different lengths and sizes.
Haymaker is offline   Top - Reply with Quote
Old 01-03-2005, 01:23 PM   #14
Peg Leg
New Member
Peg Leg is on a distinguished road
Default Pickup topper clamps
I used 2 aluminum clamps originally used to hold a aluminum shell or topper on a pickup truck. These clamps have a regular C-clamp shape with hex head bolt for tightening.
I made a jig and routed out two circular pieces, about 3" in dia, from some counter top material that I had left over. I used a fostner bit and drilled a recess for the hex head on the clamp.
I then epoxied the hex head into the recess using a product called Pig Putty. I also thought about fiberglass and golf club shafting epoxy but only because I had all of these on hand.
At any rate these are excellent for clamping to my homemade counter top router table. I picked up sink top cut outs for $2 each. They also make great fences. My router table only has a opening for the faceplate and I just place it on a pair of saw horses for portability and compact storage.
Peg Leg is offline   Top - Reply with Quote
Old 01-05-2005, 10:22 AM   #15
CanuckBeaver
Sr. Member
CanuckBeaver's Avatar
CanuckBeaver is on a distinguished road
Originally Posted by jdoolitt
Anyone else build the c-clamp handles from this shopnotes: http://www.woodworkingtips.com/etips/etip030905sn.html ?? Not having a dowel handy, I cutup an old broom and made several of these one afternoon. Easy project - inspired by the cool c-clamps used by Bob and Rick on the show. http://www.routerworkshop.com/Merchandise.html
Finding a chunk of soft rubber in this same size would be even better. Any ideas where something like that could be found?
On the first website I would try to improve by NOT notching the wooden handle.
(1)Instead drill out the center of the dowel to the correct ID and depth.
(2)Drill a hole in one side only at the correct measurement to meet the hole in the clamp handle.
(3)Place the dowel over the clamp handle and line up the holes.
(4)Drill out the far side of the dowel with your drill bit going through the clamp handle for perfect alignment.
(5)For a pin that won't fall out and so the new handle stay with the clamp I would get a drift pin (any 1/2 decent auto parts store will have these) that is a suitable size for the (metal) clamp handle and a wee bit shorter than the diameter of the dowel (file to length) if need be.
(6) If you want a rubber grip try to find some rubber garden hose, or low pessure discharge hose (NOT HEATER HOSE!) of the correct diameter to not quite slide over the dowel (maybe at that 1/2 decent auto parts store?). Place in boiling water for a few minutes (to expand the hose). (lets not forget our gloves here kids!) slide the hose over the dowel while the hose is HOT!!! and wet.
The result would be a handle that does not fall off. A slightly stronger handle but I still think a metal ring (much like the ring found on wooden file handles) around the hollowed out part of the dowel would be a good idea.
If you go with the rubber hose over dowel idea when the hose cools (contracts) and the water dries inside, it ought to have plenty of grip.
My $0.02.
CB
I've sanded so much my fingerprints are gone!
CanuckBeaver is offline   Top - Reply with Quote
trim router handles earlofroberts General Routing 9 01-15-2008 01:35 PM
Incra Clamp S Bolton Jigs and Fixtures 11 09-20-2007 10:43 AM
Handles for clear router bases. EPC General Routing 5 05-22-2007 03:29 PM
Small Wooden Clamp bobj3 Jigs and Fixtures 0 01-04-2007 06:52 PM
Pipe Clamp question ryan.s Tools and Woodworking 7 03-20-2005 04:41 PM
