| | #1 |
| Forum Contributer Supreme Forum King | Just one user review of the MLCS OnPoint Universal Laser Router Plate Now Pre-Drilled with Built-In LED Lights http://www.mlcswoodworking.com/shops...ter_Plate.html It's a great add on item for the router user,, e.g. making signs,etc. the plate is clear plastic and with the white LED lights it makes it easy to see the board under the router, the Red LED lights do put the X-cross hair right on the button. So I'm going to give it 4 stars out of 5 stars, the one star I'm holding back because they didn't put in the pocket for the brass template guides. But I think I will make a clear plastic plug to take them on,,the OD of the hole in the base plate is now 1 7/8" so it should not be a big job to make a snap-in plug .. ( the 1 3/16" size) PC type brass guides. see some snapshots below showing the new switch box for the red and white lights, plus how they have the wire in a grove in the side of the base plate with a dot or two of hot glue holding them in place and so they can be removed to replace the bulbs when needed... Just a note**** I tried to show the red and the white LED lights but the flash of the camera did wipe them out just a bit BUT they are very bright ![]() ========== OK, now I give it 5 stars, I added a clear plastic press in insert to hold the PC type brass guides....plus the white light and the red cross lines still work just fine if the brass guides are not in place... Best sign carving bit below ▼ http://www.precisebits.com/products/...rch=fromSearch see snapshots below... ▼ ==========
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 03-18-2008 at 07:13 PM. |
| | #2 |
| Marine Engineer Forum King | I get the white lights, but the laser crosshairs are lost on me. I need to know where the edge of the bit is going to be....... Still Kinda cool. I wonder how much longer before the laser scrollsaw or the laser hammer......
| | #3 | |
| Forum Contributer Supreme Forum King | Hi kp91 Many times you need to know where the point of the some bits is going to make contact with the board, like the bead bit for one the 1/8" bit for just one more ,just about any cone point or carving bit for some others some bits hide that in a way because the outside diam. of the bit..."cutters" it's true once you know the OD size of the bit you can off set the bit for it but sometime you don't need to use the full size of the bit.Sign making comes to mind right off the top of my head... It's funny you should say " laser scrollsaw " I have seen a add on for that one... The laser is coming on strong for many tools now days,tape rulers,levels, etc. and I'm sure someone is working on one for a hammer ![]() Maybe Stanley or Sears/Craftsman ... ![]() Now Harry can take off his micky mouse light and just add a new base ![]() carving bit ▼ http://www.precisebits.com/products/...rch=fromSearch ======= Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 03-18-2008 at 06:55 PM. | |
| need advice for inserting rosseau router plate into bench dog promax cast iron table | sf_basilix | Table-mounted Routing | 7 | 02-21-2008 07:00 PM |
| laser guided router plate | EPC | General Routing | 7 | 02-14-2008 11:53 AM |
| Insert Plate size and 11.5" handle spread; how to prevent problems | Ladd | Table-mounted Routing | 34 | 12-14-2007 02:08 PM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
