| | #11 |
| Registered User Dedicated Member | Here you go. I knew there was an artical here. This works fine, I have built a lot of projects using this method. Best Part is it is cheap and versitable. Let me know what you think. http://www.thewoodshop.20m.com/graph...vetail_jig.pdf
__________________ God created man, then woman and man said, Give me my wood shop! |
| | #12 |
| Forum Contributer Supreme Forum King | I know this is a old post, but if anyone is looking to make a dovetail jig forget it, unless you have a CNC machine to make the fixture, they must be dead on ![]() Each slot for each dovetail must be true to .010 for the pin and the socket and then compound that by 10 or more slots, as you can see you can make of lot of firewood real quick without the right fixture. Here's one way to beat the high cost of the fixture and you can use your plunge router or use it on your router table just like the high end dovetail jigs/fixtures. To make blind dovetail joints or dovetails that go all the way .As you know the high end dovetail jigs that you can use on the router table can be very high in price..... I got one that cost over 225.oo from sommerfeldtool.com and the one(s) below can do the same thing once you make the base block for it, so you can use it on your router table or for your plunge router. It's almost the same as the Oak-Park dovetail jig but about 1/4 the price,and it's 15" or 16" long.... ![]() See the PDF file (user guide how to make the block) But you can make one to fit your needs, plus you can make the small dovetails and the big ones with the fixture(s) below. You can also use the brass guide or the router bits with the bearing on the bottom of them,both work well with this fixture and you get the bits free when you buy the jig frrom MLCS plus free shipping.http://www.mlcswoodworking.com/shops...vetailjig.html http://www.mlcswoodworking.com/shops...15dovetail.pdf http://ca.oak-park.com/catalogue.htm...roduct=EZL0444 http://www.sommerfeldtools.com/products.asp?id=164 Just a NOTE and just one user review of the jig, Katie jig I got from sommerfeldtools it scratch, scrape, scored the Hell out of my router top base plate and the top I had to sand the jig down with 220 grit./320 grit. paper to remove all the sharp points on the Alum. parts of the fixture, but now it's to late, damage is done, a 20/20 hind site thing. ![]() Like most woodworkers when I/we get new tools we just can wait to try them out and I did just that and looked down after a made a test box and saw the table top I was mad as Hell when I saw the damage the fixture did to the base plate and top, I almost called the Mfg. but I didn't because it was my error not checking on something someone else made. .(details,details)Hope this helps someone that wants to make a dovetail jig. Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 11-09-2006 at 03:29 PM. |
| | #13 |
| Registered User | I am having the same problem regards a through dovetail. Grateful for any assistance - particularly the use of a router table, if poss. Thanks Don |
| | #14 |
| Forum Contributer Supreme Forum King | Hi Don May I show you how to make your own HIGH END dovetail jig for about 1/3 of the price or less ,,,,that you can buy it off the net.. This is a copy of the Katie Dovetail jig, one of the best on the market I think, it's like the Great Leigh jid because you can move the forks around to put in just about any pattern you want to use on your project(s) but it nwill not set you back 300.oo dollars for the Leigh type... The through dovetails are the best I think,,,the blind dovetails are ok but it's hard to get the stock cut up just right without doing alot of math, the through dovetails are easy to cut the stock for the drawers/boxes if you want a 12" x 16" drawer that what you cut the stock for...you will see many only put blind dovetails in the front of the drawer ,that's alot like only tiing one shoe up...most use glue and nails on the back side of the drawer and the through dovetails can do the job so quick and it's alot stronger...if you don't want the dovetails to show in the front of the drawer a nice face plate works the best because the stock can be the same as all the other stock on the front side.. ![]() It can be used on stock from 1/4" thick to 3/4" thick just by using the router bit,,, I like the 7/16" fort the best because, it works well for just about all type of stock. No brass guide needed to setup or put in place all the setup is done by the router bit with the bearing on it.. It can be used on the router table or clamped in the vise on the work bench.. The Katie jig sells from 120.00 to 300.oo dollars, the bigger the jig the more they cost.. The heart of the sysytem is the forks and the backbone of the system is the Alum.stock.. Lets start with the forks, you will need to buy one from Katie for the PATTERN but if you don't want to make the forks you can buy all of them from Katie But they are easy to make your own,, once you have one use some 1/2" thick stock ( wanut/maple/etc.) cut it to the right size then drill a hole in the blank for the 1/4" Allen flat head bolt,mark the stock then unbolt it and band saw some of the stock out then put the bolt back in place and use your tim bit to make the fork(s) the same thing is true for the spacers 1/2" x 1" x 3 1/2 see snapshot,,, Then you need to get the backbone of the system ( ALUM>) the rest of the parts can be just some scrap /cut offs,, MDF stock ( 3/4" ) The links are all below where to get the Alum.stock at the right price I just got 4 of them ,that are 21" long for about 8.oo bucks each...it can also be used to make a High End fence for the router table, that cost about 200.oo off the net... If you need any help just ask and I will lend you a hand,, but it's so easy to make and use you will love it like I do... ==== fork https://s.topchoice.com/thampton/order.htm $17.95 Dovetail guide/tuning fork (7/16 inch) KJ1-DVT0437A $9.99 Aluminum spacer (1-1/4inch) KJ1-35050003 http://www.katiejig.com/ Bits http://cgi.ebay.com/2-pc-Dovetail-Ro...742.m153.l1262 The one I like is below http://cgi.ebay.com/5pc-Top-Bearing-...742.m153.l1262 Alum. http://stores.ebay.com/8020-Inc-Garage-Sale ==========
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 05-19-2008 at 11:21 PM. |
| Dovetail jig | TomHerb | Starting Off | 1 | 06-28-2008 11:48 AM |
| Dovetail routing | R-Man | General Routing | 4 | 10-11-2007 09:14 AM |
| Dovetail Depth of Cut | Sherwood | Portable Routing | 5 | 09-15-2007 11:28 AM |
| New Lower Priced Leigh Dovetail Jig | scrollwolf | Jigs and Fixtures | 1 | 07-08-2007 06:10 PM |
| dovetail spline joints | reible | Jigs and Fixtures | 7 | 10-02-2004 02:50 PM |
