Help
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the largest router and woodworking community on the web! Join in over 20,000 discussions with over 40,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Has anyone ever tried to make a dovetail jig?
This is a discussion on Has anyone ever tried to make a dovetail jig? within the Jigs and Fixtures forums, part of the Routers category; Dovetail joints fascinate and confound me! I've never actually cut one, so my question may ...
LinkBack (1) Thread Tools Display Modes
Old 01-26-2005, 11:42 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
presumed_druid's Avatar
presumed_druid is on a distinguished road
Question Has anyone ever tried to make a dovetail jig?
Report Post Report This Post!
Dovetail joints fascinate and confound me! I've never actually cut one, so my question may be full of holes...
I've seen simple shopmade jigs for cutting tails (or is it pins!??) for half-lap dovetails, but never for through dovetails.
I've looked at manufactured dovetail jigs, and they look rather complicated... but the actual guide looks relatively straight forward.
Has anyone ever tried to make one?
It's in my head that some day I will try to make one... but I have the feeling that any response to this post is going to be of a negative persuasion
If I were to attempt it, what pitfalls should I be aware of?
presumed_druid is offline
Old 01-27-2005, 05:06 AM   #2 (permalink)
On vacation
template tom will become famous soon enough
Never ever having bought a jig I set out to make a dovetail Jig and produced a dovtail joint with the second cut
Tom
template tom is offline
Old 01-27-2005, 11:30 AM   #3 (permalink)
Could you describe it? Or better yet, describe it and send in a picture?
Sponsored Advertisements. Register to disable this advertisement.
Old 01-27-2005, 09:21 PM   #4 (permalink)
On vacation
I'll work on a drawing for you
Tom
Old 01-27-2005, 11:10 PM   #5 (permalink)
I appreciate it, and I'm sure that others will as well! No rush on this end... just don't totally forget about it
10% OFF at Rockler.com!
Old 01-30-2005, 01:21 AM   #6 (permalink)
hal
First Name: hal
hal is on a distinguished road
Hey Presumed, a couple of nights ago I was looking though my binder of Shop Notes and saw just what your are looking for. It is after midnight and the binder is in the shop and baby it is cold out there, so you will have to wait a day or so and I will send you the issue number. The jig looked to be well thought out and not to complicated and can be setup to make different size dovetails. I read through the plans and I think even I could build it. See you in a day or two.
hal is offline
Old 01-30-2005, 10:02 PM   #7 (permalink)
hal
First Name: hal
I looked up the Shop Notes this afternoon. What you want is issue #43 January 1999. You can go to www.shopnotes.com, and order a copy for about $4.99 that is if you can't scrounge one from someone. Hope this helps.
hal is offline
Shop now at Tool King!
Old 02-27-2005, 04:42 PM   #8 (permalink)
trap's Avatar
First Name: Ed
trap is a name known to alltrap is a name known to all
I have made a jig, not the usual type but for a splin dovetail. You can read about it at jointech.com Hit download and then scroll down to splin jig. unusual, yes, but does a really good looking dovetails.
trap is offline
Old 02-28-2005, 08:58 AM   #9 (permalink)
zxxer12 is on a distinguished road
Has any body tried one of the Rockler dovetail template master??
zxxer12 is offline
Shop now at Rockler.com!
Old 03-01-2005, 01:04 PM   #10 (permalink)
jeff12002's Avatar
jeff12002 is on a distinguished road
Send a message via AIM to jeff12002
Hi everyone, New to the site, and so far it seems great. I have built the dovetail jig from plans out of Woodsmith Magazine, which is quite likely the same one featured in Shopnotes Magazine mentioned in one of the earlier posts. It is relatively straight forward, and it does work well. Making the comb was a challenge because it has to be just right. An adjustable finger joint fixture makes this process alot easier. Once I had the finger joint jig dialed in, I made a second comb the same as the first. I then filed the round end in one of the fingers on one of the combs. clamped the two together with the fingers and slots lined up, and used the router table and a pattern bit to duplicate the rounded end on the other fingers. Rounding the ends of the fingers on the comb took less time that getting the finger joint jig dialed in. I downloaded my plans for both the adjustable finger joint jig, and the dovetail jig from www.plansnow.com for about $5 each (Both work very well). I've used the Stots Dovetail Template Master also. It works well for through dovetails. The only pitfalls I see with either set-up, and this goes for any non-adjustable jig, is that your project plans need to be planned around the jig if you want to get half-fingers on both ends of the dovetail joint. I made a drawing for a through dovetail comb for the woodsmith Dovetail Jig, but have yet to make it. (It's based off the Stots Jig)
jeff12002 is offline
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/jigs-fixtures/755-has-anyone-ever-tried-make-dovetail-jig.html
Posted By For Type Date
dovetail jig plans : information: news, videos, photos and comments about dovetail jig plans from the best web sites and blogs This thread Refback 05-07-2009 11:08 AM
Dovetail jig TomHerb Starting Off 1 06-28-2008 10:48 AM
Dovetail routing R-Man General Routing 4 10-11-2007 08:14 AM
Dovetail Depth of Cut Sherwood Portable Routing 5 09-15-2007 10:28 AM
New Lower Priced Leigh Dovetail Jig scrollwolf Jigs and Fixtures 1 07-08-2007 05:10 PM
dovetail spline joints reible Jigs and Fixtures 7 10-02-2004 01:50 PM
