Thread Tools Display Modes
Old 03-30-2008, 04:18 PM   #1
S Bolton
Forum Geek
S Bolton is on a distinguished road
Default Oak Park Spacers
I just tired using the 1/4 inch spacer. My results weren't very good.
I measured the 1/4 inch white plastic (poly?) portion of the Oak Park Spacer and find it is not 1/4 inch, but a little less.
Would this matter?
Steve Bolton
S Bolton is offline   Top - Reply with Quote
Old 03-30-2008, 04:30 PM   #2
kp91
Forum King
kp91's Avatar
Steve,
As long as the gap between the fence and the bit is 1/4 inch you should be OK. you only need to register the one side of the fence. If your joints are too loose or too tight, tap the fence closer or further from the bit. One thing I found early on is that you have to have the fence clamped down tight. If it slips during the cutting process, some of your fingers will fit, others won't.
1 John 1:9
Old 03-30-2008, 06:49 PM   #3
S Bolton
Forum Geek
Do you think the type of bit matters?
sb
Old 03-30-2008, 07:10 PM   #4
kp91
Forum King
kp91's Avatar
Spiral bits work the best, I've had some blow out with 2 flute straight cutters. If that is all you have, you can sandwich the good pieces between two scrap pieces, and the blow out will be on the scrap.
1 John 1:9
Mounting an Oak Park Box Jig on Non Oak Park Table challagan Project Plans and How To 53 09-17-2008 11:09 PM
Oak Park Spacers S Bolton Table-mounted Routing 7 11-26-2007 12:38 AM
Oak Park table old folks Table-mounted Routing 4 08-07-2007 12:08 PM
Those of you who have the Oak Park Panel System: Mossy Oak Jigs and Fixtures 1 02-14-2007 09:08 PM
