Rate This Thread - Has anyone ever tried to make a dovetail jig?.
Thread Tools Display Modes
Old 01-26-2005, 11:42 PM   #1
presumed_druid
Forum Fanatic
presumed_druid's Avatar
presumed_druid is on a distinguished road
Question Has anyone ever tried to make a dovetail jig?
Dovetail joints fascinate and confound me! I've never actually cut one, so my question may be full of holes...
I've seen simple shopmade jigs for cutting tails (or is it pins!??) for half-lap dovetails, but never for through dovetails.
I've looked at manufactured dovetail jigs, and they look rather complicated... but the actual guide looks relatively straight forward.
Has anyone ever tried to make one?
It's in my head that some day I will try to make one... but I have the feeling that any response to this post is going to be of a negative persuasion
If I were to attempt it, what pitfalls should I be aware of?
presumed_druid is offline   Top - Reply with Quote
Old 01-27-2005, 05:06 AM   #2
template tom
Forum King
Never ever having bought a jig I set out to make a dovetail Jig and produced a dovtail joint with the second cut
Tom
Old 01-27-2005, 11:30 AM   #3
presumed_druid
Forum Fanatic
Could you describe it? Or better yet, describe it and send in a picture?
Old 01-27-2005, 09:21 PM   #4
template tom
Forum King
I'll work on a drawing for you
Tom
Old 01-27-2005, 11:10 PM   #5
presumed_druid
Forum Fanatic
I appreciate it, and I'm sure that others will as well! No rush on this end... just don't totally forget about it
Old 01-30-2005, 01:21 AM   #6
hal
Jr. Member
hal is on a distinguished road
Hey Presumed, a couple of nights ago I was looking though my binder of Shop Notes and saw just what your are looking for. It is after midnight and the binder is in the shop and baby it is cold out there, so you will have to wait a day or so and I will send you the issue number. The jig looked to be well thought out and not to complicated and can be setup to make different size dovetails. I read through the plans and I think even I could build it. See you in a day or two.
hal is offline   Top - Reply with Quote
Old 01-30-2005, 10:02 PM   #7
hal
Jr. Member
I looked up the Shop Notes this afternoon. What you want is issue #43 January 1999. You can go to www.shopnotes.com, and order a copy for about $4.99 that is if you can't scrounge one from someone. Hope this helps.
Old 02-27-2005, 04:42 PM   #8
trap
Forum Fanatic
trap's Avatar
trap has a spectacular aura abouttrap has a spectacular aura about
I have made a jig, not the usual type but for a splin dovetail. You can read about it at jointech.com Hit download and then scroll down to splin jig. unusual, yes, but does a really good looking dovetails.
trap is offline   Top - Reply with Quote
Old 02-28-2005, 08:58 AM   #9
zxxer12
New Member
zxxer12 is on a distinguished road
Has any body tried one of the Rockler dovetail template master??
zxxer12 is offline   Top - Reply with Quote
Old 03-01-2005, 01:04 PM   #10
jeff12002
Dedicated Member
jeff12002's Avatar
jeff12002 is on a distinguished road
Send a message via AIM to jeff12002
Hi everyone, New to the site, and so far it seems great. I have built the dovetail jig from plans out of Woodsmith Magazine, which is quite likely the same one featured in Shopnotes Magazine mentioned in one of the earlier posts. It is relatively straight forward, and it does work well. Making the comb was a challenge because it has to be just right. An adjustable finger joint fixture makes this process alot easier. Once I had the finger joint jig dialed in, I made a second comb the same as the first. I then filed the round end in one of the fingers on one of the combs. clamped the two together with the fingers and slots lined up, and used the router table and a pattern bit to duplicate the rounded end on the other fingers. Rounding the ends of the fingers on the comb took less time that getting the finger joint jig dialed in. I downloaded my plans for both the adjustable finger joint jig, and the dovetail jig from www.plansnow.com for about $5 each (Both work very well). I've used the Stots Dovetail Template Master also. It works well for through dovetails. The only pitfalls I see with either set-up, and this goes for any non-adjustable jig, is that your project plans need to be planned around the jig if you want to get half-fingers on both ends of the dovetail joint. I made a drawing for a through dovetail comb for the woodsmith Dovetail Jig, but have yet to make it. (It's based off the Stots Jig)
jeff12002 is offline   Top - Reply with Quote
Dovetail jig TomHerb Starting Off 1 06-28-2008 10:48 AM
Dovetail routing R-Man General Routing 4 10-11-2007 08:14 AM
Dovetail Depth of Cut Sherwood Portable Routing 5 09-15-2007 10:28 AM
New Lower Priced Leigh Dovetail Jig scrollwolf Jigs and Fixtures 1 07-08-2007 05:10 PM
dovetail spline joints reible Jigs and Fixtures 7 10-02-2004 01:50 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
