Rate This Thread - Circle Cutter (Trammel).
Thread Tools Display Modes
Old 05-11-2008, 08:21 PM   #1
RustyW
Forum Geek
RustyW's Avatar
RustyW is on a distinguished road
Default Circle Cutter (Trammel)
Well I built a fence for my new table. I decided not to put any T-slots or tracks in the table. So I built a clamp-on fence(with t-tracks) I can put anywhere and still have about 7" of "fine" adjustment without un-clamping. It also has sliding faces. The t-track is from Hartville Tool and uses standard 1/4-20 hex head bolts rather than special t-bolts.
But, back on topic, I picked up a copy of Router Magic by Bill Hylton (as recommended by Bj). Theres lots of great info and jigs inside and today I built the Trammel Baseplate. I made it out of 3/4" plywood for the base and hard maple for the t-slide. It will cut a hole or a disk from about an inch out to about 16". After building it I had to try it out on a piece of scrap mdf. Rather than attaching it to a sacrificial bench top and routing all the way through. I drilled a through pin hole and plunged just less than half way through from both sides, then popped the circle out by hand. This way you can actually do it on your good bench top and then clean up the jagged little ridge with a short template bit (did I mention how much I love my new giant router table).
All of this is leading up to a project using the skis I built. Now I have a good way to produce round templates. I got a set of large guides and just need to get going on a jig holder.
circle-cutter-trammel-dscn1495.jpg  circle-cutter-trammel-dscn1494.jpg  circle-cutter-trammel-dscn1493.jpg  circle-cutter-trammel-dscn1492.jpg  circle-cutter-trammel-dscn1496.jpg
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline   Top - Reply with Quote
Old 05-11-2008, 08:42 PM   #2
Hamlin
Supreme Forum King
Hi Rusty,
TWITA!!
Ken
(On temporary leave of abscense)
"A VETERAN"
"Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown
Old 05-12-2008, 12:13 AM   #3
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
Dr.Zook is on a distinguished road
Send a message via Skype™ to Dr.Zook
Nice trammel Rusty. Looks like it does a fine job. We will be looking for pics of the ski's.
Dave
the "Doctor"
Dr.Zook is offline   Top - Reply with Quote
Old 05-12-2008, 09:48 PM   #4
RustyW
Forum Geek
RustyW's Avatar
Default Skis
Well Doc I saw your post when I got home from work. And since I see that Harrys been here today, I figure I better show all my cards(I hope its a sign that he's feeling better). But first I went in the garage and put together a new sub base fitted for the large size guides. In the pic you can see the previous one. I now make them with flat bottom recessed holes for panhead screws. I find its easier to center this way, rather than countersunk holes for flat heads. The skis, I built quite some time ago but had nowhere to use them. Now I've got no excuse on my new table.
circle-cutter-trammel-dscn1498.jpg  circle-cutter-trammel-dscn1499.jpg  circle-cutter-trammel-dscn1500.jpg  circle-cutter-trammel-dscn1501.jpg
Rusty
Old 05-12-2008, 10:59 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Rusty
I like it ,, you are getting jig making down like a pro..
Old 05-13-2008, 12:50 AM   #6
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Nicely done. I know you love that Bosch router too.
Old 05-13-2008, 11:44 PM   #7
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
Harry and I thank you for the pics Rusty. That is one large router table. I think I heard someone call one thay size as an "aircraft carrier size". Great work.
Dave
the "Doctor"
Cutter for circle jig jer760 Jigs and Fixtures 4 02-06-2008 06:16 PM
Special rabbet/rebate cutter..... challagan Router Bits - Types and Usage 8 01-31-2007 06:58 PM
Slot Cutter or Spline cutter kimbert General Routing 3 10-20-2005 06:26 PM
Rotozip for circle cutting RobertJR Tools and Woodworking 5 09-03-2005 09:36 PM
Trammel. NewMontanaWorkshop Jigs and Fixtures 0 01-17-2005 12:37 PM
