Thread Tools Display Modes
Old 02-08-2005, 07:56 PM   #1
Woofman
New Member
Woofman is on a distinguished road
Cool Slots for hand screw clamps
I'm looking for an easy way to cut the slots in the wood for the rods in the clamp kits I have.
Woofman is offline   Top - Reply with Quote
Old 02-08-2005, 08:31 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Woofman, If I understand this you are asking about making a rack to hang your clamps on?
Old 02-10-2005, 12:02 PM   #3
reible
Supreme Forum King
reible's Avatar
I guess I would first ask you what equipment you might have..... If you have a router table then I would go with that. If you have a bit that is the same dia. as the width of the slot you would just move the fence so the clamp blank is centered on the cutter. Leave the blanks as rectangles, then mark the fence on each side of the bit width...... well before I go on do you have a table?
Ed
Old 02-10-2005, 07:12 PM   #4
Woofman
New Member
Ed, I have a router set up on the end of my table saw . I tried my drill press set at an a angle to drill the holes but had to do a lot of file work.
Old 02-10-2005, 10:05 PM   #5
reible
Supreme Forum King
reible's Avatar
I am afraid my idea is not going to work. I went out and got one of my clamps in and after looking at how deep you need to go and how steep the angle my idea will simply will not have enough height to make it..... I hate when that happens...... Anyway it better to have found that out in a cad program then to have you testing it and find out the hard way......
OK some of you other people lets help this person out..... I know you have a better idea then mine, right??????
Ed
Old 02-11-2005, 12:30 AM   #6
Senior Moderator
Supreme Forum King
Woofman, you want to build a rack to hang your clamps? This is for bar clamps, Quick grip clamps, pipe clamps, c clamps? Maybe all of the above and some room for spring clamps as well? Perhaps a cubby hole for storing band clamps? I have several excellent plans and will be happy to help if you let me know what types and sizes you want to store.
Old 02-11-2005, 01:38 AM   #7
reible
Supreme Forum King
reible's Avatar
No he is making clamps..... see sketch attached for the general idea of the problem.....
WOOFMAN did you happen to use a Forstner bit in your drill press? If not that might help a lot on getting cleaner holes at the angles you need....
Ed
Old 02-11-2005, 07:58 AM   #8
steveo
Forum Fanatic
steveo's Avatar
steveo is on a distinguished road
Ed
Ed, don't mean to be too critical, but you need to re-draw the side view for the folks... think about it.
steveo
steveo is offline   Top - Reply with Quote
Old 02-11-2005, 08:11 AM   #9
steveo
Forum Fanatic
steveo's Avatar
why not just make a simple mortise in each side the rods pass through, and a simple hole on the side 90 degrees from the mortise to insert the "threaded fitting", then insert the all thread through the mortise and engage the fitting.
I know it won't exactly look like the unit at the "big box". But as my best buddy, who passed away recently, used to say, "Its close enough for the girls we hang around with".
steveo
Old 02-11-2005, 10:30 AM   #10
reible
Supreme Forum King
reible's Avatar
I guess I should have gone out to the cold garage and did this last night but here is the real thing........
Ed
Right angle clamps rharveyva Starting Off 2 03-28-2008 10:28 PM
Quick-grip clamps repair and improval simplenik Tools and Woodworking 9 06-05-2007 08:19 AM
Toggle Clamps (Update) Pop_pop1 Table-mounted Routing 1 08-29-2005 07:52 AM
T Track Toggle Clamps Pop_pop1 Table-mounted Routing 4 07-29-2005 03:22 AM
what clamps are most usefull matey General Routing 8 01-27-2005 01:36 PM
