Thread Tools Display Modes
Old 06-10-2008, 07:52 PM   #11
Hamlin
Supreme Forum King
First Name: Ken
Hi,
I understand the "theory" behind these but, this is overkill. A simple "floating tenon" can't be beat. It doesn't require extra tooling nor the time required to get the setup done.
Just my $0.02 worth.
If I stepped on any toes here, I apologize.
Ken
"A VETERAN"
Old 06-10-2008, 08:03 PM   #12
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Ken
I think they are made for the guy that only has a drill...in his tool belt
But wants to put in a good strong wood joint now and then..
Plus he doesn't know that he can buy a router combo kit for just a little bit less than the jig.... and a small add on base plate and then he has a real tool...plus some
Jig = 120.oo dollars
http://www.rockler.com/search_result...x=0&submit.y=0
http://www.rockler.com/gallery.cfm?O...Select=Details
add on plate 20.oo dollars for the router..
http://www.rockler.com/product.cfm?p...20base%20Plate
Originally Posted by Hamlin
Hi,
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-10-2008, 08:35 PM   #13
S Bolton
Forum Geek
S Bolton is on a distinguished road
I think that would be the appeal of the device. Make a good joint with a drill. It looks well made.
SB
S Bolton is offline   Top - Reply with Quote
Old 06-11-2008, 04:20 AM   #14
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Bj., as I have confessed on many occasions, at times I can be a slow learner so please be patient with me. I do not understand how the multi dowel shown in shot 0210 was made with the cutter shown in shot 0213. Could you please be patient with me and take some shots holding the bead against the cutter as it would have been set-up for each of the cuts. Thanks Bj.
Harry
harrysin is offline   Top - Reply with Quote
Old 06-11-2008, 01:09 PM   #15
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
Here's a snapshot or two that shows how to make them with one bit..
once the bit is set it should not need to be readjusted to make all the passes...the key is to use the right bit and the right size of stock, in this case it's 1 1/8"
They can be made in 3/16" diam. to 3/4" diam. in the same way...
You know I'm not a big fan of the wooden dowel pins but this way they are locked in place, unlike the standard dowel pin that acts like a pivot joint.
If I want something to turn I would use a round pin but thie best dowel pin by far is the square one...it's a locking wedge pin and it will not let the stock turn on the pin...or pivot on it..
They can be made on a standard router table but I like to use the Horz. router table anytime I need to run stock by the bit on it's edge,on the standard router table, it's just alot safer and quicker than setting the jig on the other router table...
Edge Beading Bit
http://www.grizzly.com/products/Edge...-16-Dia-/C1374
beadlock-pro-joinery-0221.jpg  beadlock-pro-joinery-0222.jpg  beadlock-pro-joinery-0223.jpg  beadlock-pro-joinery-0224.jpg  beadlock-pro-joinery-0225.jpg
beadlock-pro-joinery-0226.jpg  beadlock-pro-joinery-0227.jpg  beadlock-pro-joinery-0220.jpg  beadlock-pro-joinery-bead-bit.jpg  beadlock-pro-joinery-0228.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-12-2008, 12:04 AM   #16
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
I appreciate the time you spent on this demonstrate Bj. All became immediately obvious with the new clear shots of the cutter. Early on in your post, when you mentioned square dowels, I thought "gee whiz, Bj. has found the secret of putting square pegs in round holes" but I continued looking at the photos. and saw that you do in fact make square holes.
I have been thinking (as one does), if three holes have to be drilled, why not simply use three common or garden standard splined dowels which cost next to nothing and will in fact slightly increase the gluing area. Just a thought!
Harry
Old 06-12-2008, 12:12 AM   #17
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
You'er Welcome
It's just a new gimick that some one came up with I think, they know that wood workers will buy anything that's new...
And I think you are right 3 holes a some normal dowel rods would do the same job..
The jig just makes it easyer to drill the 3 holes right on...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-12-2008, 12:14 AM   #18
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
I appreciate the time you spent on this demonstration Bj. All became immediately obvious with the new clear shots of the cutter. Early on in your post, when you mentioned square dowels, I thought "gee whiz, Bj. has found the secret of putting square pegs in round holes" but I continued looking at the photos. and saw that you do in fact make square holes.
Harry
Last edited by harrysin; 06-12-2008 at 12:16 AM. Reason: to correct spelling error
Old 06-14-2008, 05:55 PM   #19
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Just a new way to make Knobs..quick and easy with Craftsman Router Lathe..
http://www.routerforums.com/73654-post8.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-14-2008, 06:47 PM   #20
karateed
Forum King
karateed's Avatar
karateed is on a distinguished road
Send a message via MSN to karateed
Thanks for the knob demo BJ....excellent....I'll follow your example and try this when I am able.
Just a quick question....why couldn't you just cut each knob off once you had the long grooves in the wood. I'm just wondering the purpose of the short grooves between each knob.
Thanks BJ.
Ed......:-)
karateed is offline   Top - Reply with Quote
Garage Door Joinery jimcrockett Table-mounted Routing 10 08-10-2008 11:31 PM
mini joinery winta Tools and Woodworking 11 08-28-2007 10:09 AM
Cutting board and dovetail joinery rzaccone Table-mounted Routing 2 05-12-2006 11:14 AM
