| | #71 |
| Registered User Forum King | You know we can and will BJ, Ed......:-) |
| | #72 | |
| Registered User Forum Fanatic | Hi Bj, you're welcome..I'm glad it worked ![]() it looks like you had to trim it down to fit between the rails...whats the purpose of offsetting the new plate from the tailstock? Quote:
__________________ Greg ------------------------------- | |
| | #73 |
| Forum Contributer Supreme Forum King | Hi gregW The " offsetting of the new plate " it's needed for the adjustment part of the live center tail stock..the one that came with the machine was a full threaded bolt with a sharp point on the end and a black plastic knob. see 1st set of snapshots, I could have bolted the flat steel stock to the stock tail end bar and use the 3 Allen bolts to move it in and out with a light tap with a hammer but I'm almost sure the Allen bolts will put marks on the 3/4" guide rods that's the heart of the machine, one small nick and it would stop or hang up router base plate from moving up and down the rails... Your'er right I did cut off both ends of the mouning plate to get it to fit just right...the only error I ran into was to lining it up on dead center of the mount once the bolts where free, I just made setup block to fix that error, once the setup block is in place the center point of the live center is dead on with the one in the head stock of the machine and the live center bar is just right... Now it takes about 10 sec. to line it back up once a new turning is in place and it turns nice and free now on the live center ![]() ==========
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 07-14-2008 at 11:15 AM. |
| | #74 | |
| Registered User Forum Fanatic | Hi Bob, got it..thanks ![]() I was thinking that if you bolted a plate to the tailstock with two threaded holes for your tensioning rods the live center would keep its alignment to the headstock, but it sounds like your setup block is doing the same thing. Quote:
| | #75 |
| Forum Contributer Supreme Forum King | Hi gregW I was thinking about the same lines but the threaded rods would need to be left and right hand threads on the same rods, so they could move the plate in and out much like a wooden clamp works...I have a set or two of the rods for the wood clamps but I'm a bit lazzy and I didn't want to drill and tap the holes in the tail stock plates... But if I run into a error with the way it is now I guess I will need to do that but I do like to use the KISS way most of the time...
| | #76 | |
| Registered User Forum Fanatic | Hi Bob, you're right ![]() the holes in the alignment plate would need to be a slip fit for the adjustment rods instead of threaded in order to keep it simple. Quote:
| | #77 |
| Forum Contributer Supreme Forum King | Just some more snapshots of the tail stock.. ![]() =========
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 07-31-2008 at 03:28 PM. |
| | #78 |
| Registered User Forum Geek | I am somewhat proud to have one of the longest thread on this forum. I pick good subjects. Hah. Steve Bolton |
| | #79 |
| Registered User Forum King | Very nice BJ....I have my car apart right now (my brother and I are replacing the engine) so won't get into the woodshop this week (and I'm back to work tomorrow). When I do, I'm going to finish the speaker stands and get my router craft set up and give it a whirl. Ed......:-) |
| | #80 |
| Forum Contributer Supreme Forum King | Steve, I don't wish to take any glory from you, your thread was a very interesting one however, before the end of page two it had been hi-jacked and turned into a totally different thread, this was also very interesting but I think the forum rules dictate that this should have been a separate thread.
__________________ Harry |
| Garage Door Joinery | jimcrockett | Table-mounted Routing | 10 | 08-10-2008 11:31 PM |
| mini joinery | winta | Tools and Woodworking | 11 | 08-28-2007 10:09 AM |
| Cutting board and dovetail joinery | rzaccone | Table-mounted Routing | 2 | 05-12-2006 11:14 AM |
