Thread Tools Display Modes
Old 06-22-2008, 11:36 AM   #1
RoyBullets
Sr. Member
RoyBullets's Avatar
RoyBullets is on a distinguished road
Default Determining a radius cut
I came across a note on in a article that mentions a radius cut of 40". The length of the wood piece is only about 24". I know how to cut arcs and circles from the jigs I have made for my other tools but I have not seen a radius described that way before.
Does this mean center my arc jig on the length of the board (12") and nail it down at 20" (half of 40") to achieve the correct arc for the radius.
Any help would be appreciated.
RoyBullets is offline   Top - Reply with Quote
Old 06-22-2008, 03:52 PM   #2
RoyBullets
Sr. Member
RoyBullets's Avatar
I was thinking I could have described this a little better. Does a 40" radius mean essentially a 40" circle?
I am going to try a back into the answer with a little trial and error since I know all the dimensions and how to calculate the radius.
Old 06-22-2008, 06:15 PM   #3
cbsjoez1935
Forum Fanatic
cbsjoez1935 is on a distinguished road
Roy,
If your radius is 40" (inches) then the diameter of your circle will be 80". The circumference of the circle will be 3.14 times the diameter. That's a big circle! If your board is only 24" in length, then I would think your first calculation to be right.
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline   Top - Reply with Quote
Old 06-22-2008, 06:54 PM   #4
RoyBullets
Sr. Member
RoyBullets's Avatar
Originally Posted by cbsjoez1935
Roy,
Joe Z.
Thanks Joe. The more I thought about it the more it seemed correct. I guess I have just not heard the arc described that way before.
Got tied up today but this evening I am going to just lay it out on a piece of paper and draw the radius. In this case I know what the final dimensions should be. I need to get this one right because I have a nice piece of cedar I am going to be working on.
Thanks for the help.
Old 06-22-2008, 07:17 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI Roy
Definitions of radius
* the length of a line segment between the center and circumference of a circle or sphere
* a straight line from the center to the perimeter of a circle (or from the center to the surface of a sphere)
* a circular region whose area is indicated by the length of its radius; "they located it within a radius of 2 miles"
* the outer and slightly shorter of the two bones of the human forearm
* spoke: support consisting of a radial member of a wheel joining the hub to the rim
wordnet.princeton.edu/perl/webw
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-22-2008, 09:09 PM   #6
RoyBullets
Sr. Member
RoyBullets's Avatar
Nice Bob
You forgot one:
R = ((L^2) + 4(H^2)) / 8H
Radius I understand, just not in the context that I ran across it. I am good now though.
Old 06-23-2008, 12:18 AM   #7
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
I don't know what the article is about but assume that a 24" length of wood is going to be curved, in which case mark the centre of the wood, draw a line 40" long at right angles to the centre of the wood and with a jig or a piece of string with a pencil tied to it's end draw an arc on the wood. These shots show in a crude but fast demo.of how I interpreted your first post.
Harry
harrysin is offline   Top - Reply with Quote
Old 06-23-2008, 09:10 AM   #8
Tale Gunner
Jr. Member
Tale Gunner's Avatar
Tale Gunner is on a distinguished road
Harry you are correct. Here is a picture that I refer to all the time to keep my mind straight.
[IMG][/IMG]
Tale Gunner is offline   Top - Reply with Quote
Corner Radius bobj3 Tools and Woodworking 25 09-29-2007 06:51 PM
Working with radius MiamiSnookII Starting Off 5 01-07-2006 11:20 AM
3/4" Radius roundover bit with 1/4" shank chrisogrady General Routing 8 04-01-2005 09:08 PM
Router Table Plate Radius DONALD Table-mounted Routing 2 02-27-2005 10:26 AM
