Thread Tools Display Modes
Old 10-11-2008, 01:53 AM   #31
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Originally Posted by john heff View Post
Hello Harry,
I missed seeing that template in your post the first time that I viewed it, thanks for pointing it out to me. Speaking of that shot #4, I am totally confused and hope you can set me straight (I hope I can describe it so that you can understand it).
It appears to me that the router is positioned 'right-center' on the rods and is also at the right side of the template. Do you slide the router back-and-forth on the rods while you are running the router? i.e. when you are cutting a square pattern do you slide/move the WOODEN SKIS when making the vertical cuts and then slide the router ON THE RODS to make the horizontal cuts (leaving the wooden skis in position without moving them horizontally)? Or is the router fixed FIRMLY to the rods and you move only the skis to make the cut? Or can you do it BOTH ways? Regards, John
John, the router IS locked onto the skis and it's position depends on the project and size of the bench. It isn't unusual for me to re-position the router on the skis several times whilst routing so that the skis don't drop off the table. This link to an earlier project of mine showing how to rout a trinket box out of solid wood should give you an insight into ski routing.
http://www.routerforums.com/guide-bu...ff-router.html
I've just had a peep at that project and see that in those days photographs would become jumbled irrespective of the order in which they were posted, also it was before I learnt how to add text.
Harry
harrysin is offline   Top - Reply with Quote
Old 10-12-2008, 07:46 PM   #32
allthunbs
Sr. Member
allthunbs is on a distinguished road
Harry and Bob: Hold on a minute.
I bought two pieces about 14" long of 12mm threaded steel rod. It was all I could find. I figured I could put the boards on the end and use thumbscrews to locate the router across the bars. But the way you two talk, is you fix the locations of the end boards and they pretty much stay there. I have to assume from the pictures I've seen, that you adjust the height of the router at the boards, but locate the router with the thumbscrews?
allthunbs
allthunbs is offline   Top - Reply with Quote
Old 10-12-2008, 10:55 PM   #33
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI allthunbs
That's what I do but Harry doesn't care for all thread rod but it works great for me..
I will say I don't need to make a template(s) or use one with the all threaded rod..just lock the stock in place move the router into place lock it with the thumb screws and drop and slot...
here's a shot of a feather boards I made today with the ski jig...(a pair of them)
Putting in a slot can be tricky but it's easy with the ski jig and it's safe way...
3/4" thick Cherry , 3/8" wide slot 5" long...
Plus you will see RustyW setup below..
skis-0482.jpg  skis-0484.jpg  skis-7315.jpg  skis-rustyw-ski-jig.jpg  skis-rustyw-router-table.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-13-2008, 08:00 AM   #34
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
allthunbs
Hi AT, whilst your rods are rather on the short side, limiting the projects that can be accomplished, they are still long enough for heaps of small projects. The rods are adjusted at the end cheeks so that the base of the router is just a little clear of the wood, it's important that all four corners are at the same height. With my rods it's only necessary to tighten a wing nut at each corner, but with threaded rod you would require a nut and washer on each side of the cheek at each corner. With short rods like yours, the router would be locked at approx. centre of the rods with the screws that are on the router for securing the supplied side fence. Once the skis have been set, the router's depth stops are used to determine the cut. The attached photo, whilst showing the router mounted on my circle cutting jig, illustrates how the router is locked on the rods. Don't forget that the assembly is controlled by holding the end cheeks, NOT the router.
Harry
Old 10-13-2008, 03:01 PM   #35
allthunbs
Sr. Member
Have you ever done it the other way? i.e. lock the skis and slide the router across the rods? I have a bunch of grooves to cut in some face frames. The sticks are 4/8/12 feet long. I was going to gang a bunch together and using a template and guide bushing do them that way. However, if all I have to do is slid the skis into place, lock them and cut the grooves, that would be a lot quickier. Suggestions?
Allthunbs
Old 10-13-2008, 03:20 PM   #36
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Allthunbs
I have not try that, the router likes to move when it starts the pass..
I would try this, clamp the router in place then lock it in place then just slide the stock under the router base.
With some boards on both side of the stock to keep it running true under the router..
Allthunbs
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-14-2008, 03:03 PM   #37
oleo40
New Member
oleo40 is on a distinguished road
I am very new to this site but is there some where to find the plans for Ski's. Very interesting but not sure how/to from the pictures I see [or not Seeing]
Ole
oleo40 is offline   Top - Reply with Quote
Old 10-14-2008, 09:42 PM   #38
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Ole, you can build your own with out any plans. The size of your workbench comes into play with how wide you can build your ski's. A good size would be rods 18" in length, that should cover most small projects. The rods need to be 1/2" diameter to keep from flexing. Insert them through your router so they are even on both sides, apply some lipstick to the ends of the rods and then press them against the wooden end pieces. This will transfer a nice mark where the two holes need to be drilled. Repeat for the other side. This should have you on the right track.
Old 10-14-2008, 10:41 PM   #39
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Mike
I learn something new ever day on the great forum I guess that's why I like it so much, I didn't know you had a set of the ski jig..
I would love to see your setup...on the Bosch router..maybe I can steal a tip or two from your setup for the next set I'm going to make..
I'm going to pickup a Bosch router just for kicks and give it a try out..
Just some snapshots would do the trick I think.. thanks
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-20-2008, 10:44 PM   #40
levon
Sr. Member
levon's Avatar
levon is on a distinguished road
Default ski sled?
i have been looking and im sure i missed it, but what are skis used for?
levon
levon is offline   Top - Reply with Quote
My first sign hbk409 Show N' Tell 32 10-06-2008 04:26 PM
This time out of Jarrah harrysin Woodturning and Lathes 32 10-06-2008 01:21 PM
how to use skis - other devices? allthunbs General Routing 1 08-15-2008 04:22 PM
Circle Cutter (Trammel) RustyW Jigs and Fixtures 6 05-14-2008 12:44 AM
A use for 'skis' Drugstore Cowboy General Routing 1 01-27-2008 01:04 PM
